Author Topic: How to decrease pump flow???  (Read 8039 times)
Offline Bio-boy
« on: May 12, 2015, 10:29:27 AM »
Is it simply a case of restricting the flow into the pump i.e. could you use a valve and partially close it?
I have a pump capable of flowing 350L/min at 6m head and would like to know how, if possible the flow rate could safely be restricted.
I'm thinking by partially restricting the flow via a valve it would act in a similar fashion to increasing the head. Would I be wrong in thinking this? I appreciate that there would come a point that too greater a restriction would damage the pump due to excessive load.
Re: How to decrease pump flow???
« Reply #1 on: May 12, 2015, 10:42:30 AM »
you want to restrict the flow into the pump, not the flow out of it
how much do you want to restrict it by ?
« Reply #2 on: May 12, 2015, 10:43:30 AM »
No you don't. If you restrict flow into the pump, you run the risk of cavitation.
Restrict the flow out of the pump with a valve.
Or...use a variable speed drive (assuming the motor is 3 phase).
Restricting the pump does not cause an increase current draw in the motor. The power delivered is a product of head and flow rate. Reduce the flow rate, you reduce the power required by the impeller - thus the current drawn by the motor.
You will, initially see a rise in current as you start to increase head. But it will drop off when you go too far. You can't overload a pump by throttling it. In fact, the only way I can really think of is by either pumping a fluid that's viscous, or by running it too fast - but again, you'll need a VSD for that.
« Last Edit: May 12, 2015, 10:54:39 AM by therecklessengineer »
« Reply #3 on: May 12, 2015, 11:52:57 AM »
Totally agree, you're pretty much guaranteed cavitation with methanol in the mix and restricting the input flow :)
The only risk with restricting the output is heating the pumped liquid, so long as there is some flow you will be OK.
« Reply #4 on: May 12, 2015, 12:08:34 PM »
You could loop the flow back to the feed.  That way you would not actually restrict the pump movement at all, but reduce your flow all the same.
« Reply #5 on: May 12, 2015, 12:28:28 PM »
Bio Boy,
It may be an idea to try to measure the flow before you start to think about restricting it. With most bio/oil mixes the pump flow is about 50% of the quoted amount with water. Drum tested his 105 at 29lpm and my 120 is down to 34lpm with cold oil.
May I ask you what sort of pump is it.
« Last Edit: May 12, 2015, 12:30:57 PM by dgs »
« Reply #6 on: May 12, 2015, 12:39:58 PM »
Mr engineer and Tony, I'm sure I have seen some posts on infopop where some say cavitation produces better mixing.
I find that surprising, but not unbelievable.
Certainly though you'll find your impeller erodes with cavitation.
« Reply #7 on: May 12, 2015, 12:54:38 PM »
I was told a long time ago by an engineer to always limit on the input if you can
but as julian said, if it's your mixing pump... put a loop between the input and output (with a valve on it)
slower flow through your reactor tank
but max flow through the pump for max in pump mixing :-)
« Reply #8 on: May 12, 2015, 05:27:18 PM »
This appeared on youtube a while back ...
https://youtu.be/Abw3dG0SB0g
and
https://youtu.be/6BXy_vTNju8
« Last Edit: May 12, 2015, 05:28:53 PM by Julian »
Offline Bio-boy
« Reply #9 on: May 12, 2015, 10:00:47 PM »
Bio Boy,
http://www.oilybits.com/pumps-for-liquids-/pedrollo-pro-nga-open-impeller-316-stainless-steel-centrifugal-pump.html
« Reply #10 on: May 12, 2015, 10:27:30 PM »
so.... why do you want to limit the flow ?
« Reply #11 on: May 13, 2015, 06:19:08 AM »
That is a good question...
Offline Bio-boy
« Reply #12 on: May 13, 2015, 08:27:48 AM »
As it flows 300+ litres per minute and I have concerns that whilst it will be OK for the reaction it may be too much for the drying/filtering stage as at 6Bar will it not simply crush the cartridge filter see below:
http://www.oilybits.com/filters/elements-complete-with-housings/pentek-20-big-blue-polypropylene-filter-housing-1-5-bsp-ports.html
If you all think it will be fine then happy days. That's why I thought I would ask the question as there is a lot of knowledge on this forum.
« Reply #13 on: May 13, 2015, 08:32:56 AM »
From the specs it looks to be a low pressure high flow pump.  The 6 bar is almost certainly the rating for if this is used as a booster pump in an already pressurised system, I very much doubt it will push 6 bar on its own, but without a datasheet showing the pump curves it's impossible to tell.  It is very much a pump that a small amount of restriction will slow the output considerably.
What process are you planning to use (why do you want to filter the processor's discharge?)
« Reply #14 on: May 13, 2015, 09:45:54 AM »
Filtration systems always work more efficiently at lower flows. I would consider purchasing a low flow pump for your filtration. I did consider getting a pump similar to yours for my new set up, but having had a word with jamesrl he told me to go with lower flow and higher pressure for the process pump, so I went with the TAM 120 and a 1/2'' eductor and my goodness, does it work well.
For my filtration pump I use an adjustable flow geared pump, I have it set on 4.3 litres/min to go through 1 and 0.5 micron filters.
