Author Topic: How to decrease pump flow???  (Read 8038 times)
Re: How to decrease pump flow???
« Reply #15 on: May 13, 2015, 12:43:01 PM »
As Tony said. That 6 bar won't be with any flow - that'll be the max value.
Edit: Here's the pdf: http://www.oilybits.com/downloads/PEDROLLO-NGA-PRO-50HZ.pdf
Not 6 bar. 0.6 bar@max flow up to a maximum of 2 bar. Someone's made an oops.
Thought it sounded a bit odd. 6 bar @ 350l/min is approx 3.5kW.
« Last Edit: May 13, 2015, 12:47:30 PM by therecklessengineer »
« Reply #16 on: May 13, 2015, 03:08:15 PM »
Good find on the datasheet.  At max head (20m) it'll be pushing about 1.8 bar with bio.
« Last Edit: May 13, 2015, 03:10:10 PM by Tony »
« Reply #17 on: May 13, 2015, 03:38:39 PM »
Not really. It was linked at the bottom of the oilybits page.  ;)
« Reply #18 on: May 13, 2015, 04:50:38 PM »
Oh yes, so it is  ::)
Offline Bio-boy
« Reply #19 on: May 13, 2015, 09:52:57 PM »
Thats good I think?!?! So what should the flow rate be at zero head with bio? At least it shouldn't destroy my filters.
« Reply #20 on: May 14, 2015, 07:33:53 AM »
Theoretically, zero bar. To put a number on it you'd have to know the flow restriction of the filter and the pipework.
I guess it'd probably sit about 1 bar ish. You won't get more than 2 bar out of the pump.
« Reply #21 on: May 15, 2015, 01:13:15 AM »
had a couple of drinks... but last few posts are confusing me
1 bar is 10m of head (close enough to 10 anyway)
pump does 20m head at most, so max pressure out of the pump is about 2 bar (about 30psi)
at that head, the flow (with water) is 50l/min
that's the max head, so even if you restrict the flow more, the pressure won't increase any more
pressure when filtering will depend on how restrictive the filters are, but should still max out at 35psi
the less pressure you have at your filters the better tho... less chance of pushing crap through them
« Reply #22 on: May 15, 2015, 07:26:25 AM »
Bang on.  :)
