Author Topic: new addition  (Read 29281 times)
Re: new addition
« Reply #15 on: May 05, 2015, 08:29:50 PM »
Excellent stuff Ged and Simon, I wish I had more time to get back into experimenting and trying ideas out its great, keep up the good work chaps
Re: new addition
« Reply #16 on: May 05, 2015, 08:43:09 PM »
 ;D
its coz we is tight..... :o
Offline Rossey
Re: new addition
« Reply #17 on: May 05, 2015, 08:53:57 PM »
Sounds good to me.
I will need one for 22mm pipe.
Re: new addition
« Reply #18 on: May 05, 2015, 10:17:45 PM »
by no means are my fluid mechanics as good as my land rover mechanics
From my fairly long experience of Land Rover mechanics, it's nothing more complicated than hitting bits with a hammer.
The weight of the hammer being directly proportional to the severity of the problem.
Re: new addition
« Reply #19 on: May 05, 2015, 10:29:37 PM »
cant be that long.
or you would know that rust spiders are scared of hammers.....
Offline simonallen
Re: new addition
« Reply #20 on: May 06, 2015, 07:23:17 AM »
there aint much on there i'd be comfortable hitting with a hammer, it's a bit "crusty" lol.
if you close the door, not only does the window drop down but half it's underside drops off and hits the floor!
Re: new addition
« Reply #21 on: May 06, 2015, 04:52:46 PM »
The more bits that drop off the less there is to go wrong.
Offline Rossey
Re: new addition
« Reply #22 on: May 11, 2015, 02:37:15 PM »
Any news on this, want one  ;D
Re: new addition
« Reply #23 on: May 11, 2015, 04:48:39 PM »
i got it this morning mate, but i seem to be having a bit of car trouble...
http://www.biopowered.co.uk/forum/index.php/topic,2508.0/topicseen.html
ive glanced at it and it seems ok,
no restriction at all on the veg side (unenergised)
but i will need to get a new fuel tank made to fit the new car so wont be fitting it for a few weeks.
Ged
Re: new addition
« Reply #24 on: May 14, 2015, 10:00:41 AM »
whats the going rate for a 205 cone bottom custom order.?
oh, and simon is back of holidays if anyone needs a nozzle
Offline Twenty4Seven
Re: new addition
« Reply #25 on: May 14, 2015, 11:03:23 AM »
Leaky or non-leaky?
Re: new addition
« Reply #26 on: May 14, 2015, 11:33:39 AM »
Err, none leaky? ???
Braised around the immersion ring for added safety.
Offline simonallen
Re: new addition
« Reply #27 on: May 14, 2015, 04:40:00 PM »
competely brazed, not soldered  8)
Re: new addition
« Reply #28 on: May 14, 2015, 06:09:19 PM »
It'd have to be a steel 2 1/4" immersion ring 'cause you can't braze a brass one, if you have a steel one why not weld it on.
Offline simonallen
Re: new addition
« Reply #29 on: May 14, 2015, 07:12:32 PM »
I used a steel threaded insert for ged's. I have sifbronze no1 rods, so can braze brass to steel easily.
Its also hard to weld a 10mm pice of steel to a 1mm drum, especially when the insert is flat and the drum is round. Lots of potentil to either blow through, or get leaks in between a stop-start weld
