Author Topic: recommend forum like this but for bioethanol ?  (Read 4103 times)
Offline zatawitono
« on: June 03, 2014, 06:44:15 PM »
i want to find 1 forum like this , but the topic is bioethanol . for gain my knowledge
Re: recommend forum like this but for bioethanol ?
« Reply #1 on: June 03, 2014, 07:18:24 PM »
Isnt the process pretty much the same?
I would imagine you would have to speak to the americans - in the uk, ethanol is much more expensive, so noone uses it.
« Reply #2 on: June 03, 2014, 07:26:55 PM »
Can't say I've come across one dedicated to ethanol use.
We could look at an ethanol section on here ... we have many ethanol experts as members, but their experience is limited to human consumption.
What experience of ethanol as a fuel do you have?  I assume you are thinking of manufacture from biomass.
« Reply #3 on: June 03, 2014, 08:35:44 PM »
Hi all
Just a quick reply to this but the production of any kind of ethanol in this country is very heavily regulated so would never be allowed as a hobby .
For me to do it I would need to jump many many hoops so will be leaving that till I retire.
Paul
« Reply #4 on: June 03, 2014, 08:39:51 PM »
The OP in in Indonesia.
Hi ya Paul, how y'doin'?
« Reply #5 on: June 03, 2014, 08:46:11 PM »
Indonesia seems to be a bit finickity about alcohol too.
Is it just basically the same alcohol as what is in liquor, just that it doesn't have to taste nice, and it's in bigger quantitys?
« Reply #6 on: June 03, 2014, 08:58:42 PM »
Spot on.
Its just the next in the series.
Methanol -
Ethanol -
« Reply #7 on: June 03, 2014, 09:13:41 PM »
It looks simple to produce. Could be pretty handy in a petrol back up genny, so long as the fact wasn't broadcast all over the place.
« Reply #8 on: June 03, 2014, 09:22:21 PM »
The issue with ethanol production from biomass is that the energy required to boost the percentage ethanol (ie distillation) is significant.
I saw a website years back where a chap in america was sorting out enough to run his mower on, through windfall fruit, and a solar still, but its a lot of effort for not much return.
Yeasts will die at less than 20% volume of ethanol.  So, for a couple of hundred litres of product, youll need to brew over 1000ltrs of fluid.
« Reply #9 on: June 03, 2014, 09:32:30 PM »
Ahh, not as simple as it seems then.  Oh well.
Offline zatawitono
« Reply #10 on: June 03, 2014, 09:36:13 PM »
thanks all for the reply and the information that you give .
« Reply #11 on: June 04, 2014, 11:09:43 AM »
There are much better ways of generating petrol-like fuel substitutions.
One such method is to use heat to break down a feedstock into what chemists call Syngas - a mix of CO and H. This will run a stationary engine directly, but could be combined into hydrocarbons by using the Fischer–Tropsch process. The resulting hydrocarbon mix can then be spilt by fractional distillation. The Fischer-Tropsch can be tuned to produce the bulk of the hydrocarbons of a specific length.
The beauty is with this method, is doesn't matter what your feedstock is as long as it's organic. Tyres, plastic, newspapers, grass clippings, doesn't matter. Although moisture tends to screw with it a bit.
It's something I'd very much like to play with at some point.
« Last Edit: June 04, 2014, 11:16:00 AM by therecklessengineer »
« Reply #12 on: June 04, 2014, 11:39:37 AM »
Hi all
Paul
Hi Paul.  Hope you are well.
Good to see you back on the forum, shame about the over regulation.  It wouldn't stop us discussing how to do it though.
« Reply #13 on: June 04, 2014, 11:40:47 AM »
All sounds very interesting ... wikipedia says you can make methanol with that method.
« Reply #14 on: June 04, 2014, 08:06:43 PM »
i looked into this years ago to make organic methanol. the problem is you need a licence for a still from hmrc. i did try to get one. but as paul says too many hoops. bonded warehouse  regular inspections lots of paperwork. try it without telling them and  you are in big trouble,if you dont blow yourself up of course. i believe some  eastern europeans may be able to help.
