Author Topic: Turbo wanted, puny ones need not apply! >:(  (Read 9135 times)
Re: Turbo wanted, puny ones need not apply! >:(
« Reply #30 on: April 02, 2014, 09:58:21 PM »
https://www.youtube.com/watch?v=bMWFkr24tdI
This guy seems to have built what I would like to build. It starts on gas (propane) warms up the ignition chamber and when correct temperature is reached he lets diesel into it.
I have just checked my shed and I have one of these:
http://www.yachtshop.it/code_osculati/1740300/Osculati%20-%20fuel%20solenoid%20valve%2012V%20RINa%20%5B17.403.00%5D
I can use that to shut off liquid fuel. Another guy had built a similar engine and had used 3 pids in series connected to various sensors and it would shut down if any of the pids detected operation outside the parameters.
Now I need to experiment with nozzle making!
« Reply #31 on: April 02, 2014, 10:35:30 PM »
I have a new 12V fuel shutoff valve sitting unused, yours if you want it.
« Reply #32 on: May 02, 2014, 11:14:55 PM »
James we forgot the steel pipe for Kamaangir on your last visit
is there a way to get it to him now.
« Reply #33 on: May 02, 2014, 11:29:21 PM »
We'll have to see if we can set up a rely on the other channel.
« Reply #34 on: May 02, 2014, 11:35:13 PM »
Hopefully the relay service will come to the rescue will you
post it up or shall I.
« Reply #35 on: May 02, 2014, 11:36:42 PM »
Relay advert done.
« Reply #36 on: May 02, 2014, 11:46:00 PM »
Noted and added a bit of info
