Author Topic: what you running  (Read 44125 times)
Re: what you running
« Reply #60 on: December 31, 2013, 05:44:48 PM »
Ok, I've transferred all the data to the sortable table.
Can those who have already filled it in check that my ant like brain has transferred all the data correctly please.
Also can people alter their mileage to start with a total, numerical figure I think it should be ok to qualify it with text, just so long as it starts with a number.  That way the sort facility will make sense.
« Last Edit: December 31, 2013, 05:48:35 PM by Julian »
« Reply #61 on: December 31, 2013, 05:52:31 PM »
Any futire additions to the list (let's hope there are many) can be added direct to the spare rows or this format filled in and pasted here for upload to the wiki by a willing member ...
<!--Make-->|
<!--Model-->|
<!-- Year-->|
<!--Member-->|
<!--Fuel-->|
<!--Mileage-->|
<!--Problems-->|
<!--Cures-->|
Just add your data after each vertical line.
« Reply #62 on: December 31, 2013, 06:09:27 PM »
Briggs and Stratton  6.0HP Petrol  2000  TheRecklessEngineer  B100  5 years  Needs propane to get it going. Clouds of white smoke until warm, then more white smoke. Frequent spark plug fouling. Contamination of lube oil  Breathing mask. Addition of petrol helps with the smoke.
« Reply #63 on: December 31, 2013, 06:17:24 PM »
An explanation and especially some photos would be interesting!
Offline thewormman
« Reply #64 on: December 31, 2013, 07:03:42 PM »
Added mine
« Reply #65 on: December 31, 2013, 08:38:24 PM »
Willbuild. peugoet partner 1.9d 2006 9000 miles on b100. no problems ( touch wood)
« Reply #66 on: December 31, 2013, 08:56:07 PM »
Done
« Reply #67 on: December 31, 2013, 10:04:29 PM »
Just added mine
« Reply #68 on: January 01, 2014, 09:48:32 AM »
its in the list a petrol engine running on bio
« Reply #69 on: January 01, 2014, 10:52:39 AM »
Yes, that's a tortured lawnmower of mine. I'll get a video next time I get it out of the shed.
« Reply #70 on: January 01, 2014, 11:33:43 AM »
Low compression petrol engines will run on diesel/Bio, as a teenager I had a Triumph Tigress 250cc scooter which had 6/1 compression, I used to nick some of dads heating oil and add it to the petrol, a pig to start if you added too much and plenty of white smoke especially on overrun but did get me to the next months pay. lol
« Reply #71 on: January 01, 2014, 12:08:29 PM »
« Reply #72 on: January 01, 2014, 04:57:23 PM »
I've added my cars, but it's not formated properly, can someone sort this out please.
« Reply #73 on: January 01, 2014, 05:00:55 PM »
I think a modifications section needs to be added so we can tell the whole story.
« Reply #74 on: January 01, 2014, 05:08:26 PM »
Have you met Nige?
You really must keep up, Mark.  The table changed it's format from html to be a searchable wiki format.
You should have used this format ...
<!--Make-->|
<!--Model-->|
<!-- Year-->|
<!--Member-->|
<!--Fuel-->|
<!--Mileage-->|
<!--Problems-->|
<!--Cures-->|
I'll delete the old html post so other silly bastar people don't do the same.
With the new format, just stick your data after each vertical line and make sure that the vertical line and dash (|-) are between each set of data.
If you want to copy the data to repopulate the new format, I'll leave it in place for an hour or two before correcting it so you can insert the new stuff.
« Last Edit: January 01, 2014, 05:19:29 PM by Julian »
