Author Topic: Venturi or diffuser  (Read 2047 times)
Venturi or diffuser
« on: December 10, 2013, 06:44:47 PM »
What's the best way to de-water?
Is it with the venturi going full tilt or using a diffuser?
Re: Venturi or diffuser
« Reply #1 on: December 10, 2013, 07:09:38 PM »
My personal preference is a diffuser.
I find it quicker, I dry at 70c so with a 30min settling period after drying the temperature is just right to go straight into the first stage of conversion.
« Reply #2 on: December 10, 2013, 07:21:12 PM »
Is the 30min settling period just about lowering the tempearture or does it have other benefits?
« Reply #3 on: December 10, 2013, 09:20:24 PM »
As I use a separate drying tank the settling period allows BCBs to sink before transfer, the temperature I don't worry about, I'll add methoxide anywhere between 60 and 80c.
« Reply #4 on: December 10, 2013, 09:33:50 PM »
I also add the metoxide between 60 and 75c and have been wandering if 75c was to hot as the methanol might start to evaporate out of the mixture? I realise that any that does evaporate would condense and fall back in but it never hurts to ask.
« Reply #5 on: December 10, 2013, 09:53:14 PM »
If you have a condenser and sealed vapour system, as you should have on a GL, you might get as much as an eggcup full condense out so don't worry.
