Welcome,
Guest
. Please
login
or
register
September 10, 2025, 01:19:03 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
Biodiesel
Chemistry and process
Venturi or diffuser
« previous
next »
Print
Pages: [
1
Author
Topic: Venturi or diffuser (Read 2043 times)
nigelb
Wiki Editor
Grand Gunge Master
Venturi or diffuser
on:
December 10, 2013, 06:44:47 PM »
What's the best way to de-water?
Is it with the venturi going full tilt or using a diffuser?
Logged
Jamesrl
Wiki Editor
Oil baron
Re: Venturi or diffuser
Reply #1 on:
December 10, 2013, 07:09:38 PM »
My personal preference is a diffuser.
I find it quicker, I dry at 70c so with a 30min settling period after drying the temperature is just right to go straight into the first stage of conversion.
Logged
nigelb
Wiki Editor
Grand Gunge Master
Reply #2 on:
December 10, 2013, 07:21:12 PM »
Is the 30min settling period just about lowering the tempearture or does it have other benefits?
Logged
Jamesrl
Wiki Editor
Oil baron
Reply #3 on:
December 10, 2013, 09:20:24 PM »
Quote from: nigelb on December 10, 2013, 07:21:12 PM
As I use a separate drying tank the settling period allows BCBs to sink before transfer, the temperature I don't worry about, I'll add methoxide anywhere between 60 and 80c.
Logged
willbuild
Valve head
350 slc what i save on bio, I spend on this
Reply #4 on:
December 10, 2013, 09:33:50 PM »
I also add the metoxide between 60 and 75c and have been wandering if 75c was to hot as the methanol might start to evaporate out of the mixture? I realise that any that does evaporate would condense and fall back in but it never hurts to ask.
Logged
Jamesrl
Wiki Editor
Oil baron
Reply #5 on:
December 10, 2013, 09:53:14 PM »
If you have a condenser and sealed vapour system, as you should have on a GL, you might get as much as an eggcup full condense out so don't worry.
Logged
Print
Pages: [
1
« previous
next »
Biodiesel
Venturi or diffuser
