Author Topic: non titration 2 stage  (Read 5573 times)
Offline hifly
    • waste oil devizes
« on: June 21, 2011, 12:22:43 PM »
I have make a page for non titration processing by editing the data from the 2 stage page , let me know if its ok of if i have done somthing wrong.
you may want to check my spelling and add a few back links.
Cheers
hifly
« Last Edit: June 21, 2011, 01:19:46 PM by hifly »
VW T4 2.5Tdi
Re: non titration 2 stage
« Reply #1 on: June 21, 2011, 01:52:12 PM »
Hey looks good!  ;D
Linky: http://www.biopowered.co.uk/wiki/Two_stage_process_with_no_titration
I've resaved the front page so it's automatically included in the list of links.
I've also tidied the page up a bit, nothing drastic though.
« Last Edit: June 21, 2011, 02:07:33 PM by tony »
« Reply #2 on: June 21, 2011, 02:58:56 PM »
very nice chap!  8)
« Reply #3 on: June 21, 2011, 06:57:23 PM »
Nice page, well done Vince.
There's a bit of a discrepancy with the 3/27 page which says the test isn't quantitative.  It's a point on which I've never been sure and have seen people upholding both points of view.
If it works as Vince describes we may need to modify the 3/27 page.
Offline hifly
    • waste oil devizes
« Reply #4 on: June 21, 2011, 09:53:47 PM »
the last time it was talked about on the veg forum a number of people came out of the woodwork saying they did just as i had said and it worked fine.
It may not be quantative but also titrations don't take account of any water or other stuff thats in the oil so i think they are also not quantative even though we spend so much time and effort trying to be as accurate as possible.
I may change the wording to say that many people dismiss this methode but normally not the one who have tried it.
VW T4 2.5Tdi
« Reply #5 on: June 21, 2011, 09:59:26 PM »
yes maybe a good piont to change, cover all bases...
« Reply #6 on: June 21, 2011, 11:34:20 PM »
I don't really know enough to make a judgment, I currently just 2 stage process to achieve a clear pass,  however I think it's important that the wiki doesn't offer conflicting information.  Vince, your system obviously works so it must, to a degree at least, be quantitative.  How about both pages use the term "indicative of percentage conversion" or something similar?
Tony, you put the 3/27 page together ... any thoughts?
« Reply #7 on: June 22, 2011, 01:26:14 AM »
"Not quantitive, but good enough to work in this situation"?
« Reply #8 on: June 22, 2011, 08:41:18 AM »
quantum leap
 ;D
Offline StevieboyTD
« Reply #9 on: July 13, 2011, 11:00:07 AM »
Just wondering if it's possible to expand part 5 "Determine the amount of unprocessed oil in your batch from the dropout." to give a couple of sums as to what i measure and what i do with the numbers.
27/3, measure 1.2ml of dropout, my initial batch was 50L of oil, where do i go from there? (that sort of thing!)
Cheers
'98 306 1.9 dturbo bosch
'98 406 2.1 exec bosch
« Reply #10 on: July 13, 2011, 11:09:44 AM »
Good idea.
This is the part in question:
http://www.biopowered.co.uk/wiki/Two_stage_process_with_no_titration#The_process
Make up the second stage Methoxide by mixing "20% batch size Methanol" with "unprocessed oil volume x base" catalyst.
So I guess if you have 1.2ml in 3ml, that's 40% unconverted, or 20l unconverted from a batch of 50l.
So you'd need 20% of 20l in Methanol (4l) and 5g NaOH * 20l (100g) catalyst?
Hifly can you confirm this this correct?
Offline hifly
    • waste oil devizes
« Reply #11 on: July 13, 2011, 10:38:10 PM »
a calculator was done by someone, here is a link
http://www.mediafire.com/?zd8diwrz35asns7
the only thing unclear about it is where it says % meth used, it means % meth for second stage
here is the thread i got the link from.
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=24395&page=1#pid273916
If there are any more questions it will be best to e-mail me as i'm getting fed up with the atitude of some forum members so won't be visiting the veg forum for the forseeable future.
VW T4 2.5Tdi
« Reply #12 on: July 14, 2011, 09:35:30 AM »
Sorry to hear that Vince :(
I'm thinking about giving this no-titration lark a shot for my next batch too.
« Reply #13 on: July 14, 2011, 05:28:15 PM »
Now we  have a chatter section i hope you will pop up from time to time on here Vince :)
