Author Topic: Cam and Groove fittings and direction of flow?  (Read 4713 times)
« on: December 06, 2013, 11:12:43 PM »
These sort of things -
Should the flow be male to female, or does it not really matter?
If it does matter, how much does it matter?
(im only wanting this for fluid transfer, no high flow / pressure processing applications)
Re: Cam and Groove fittings and direction of flow?
« Reply #1 on: December 06, 2013, 11:17:44 PM »
The only ones I've seen in use were male to female, this was for transfer powder in an airflow.
« Reply #2 on: December 06, 2013, 11:18:03 PM »
Hydraulics on tractors have those sort of fittings, but much stronger. They flow out of the female, which is mounted on the tractor, and into the male, on the attachment. You do sometimes see it the other way, when there is a possibility of high pressure returning to the tractor, so I guess that is the way to do it.
Offline jkis
« Reply #3 on: December 07, 2013, 05:20:00 AM »
i don't believe it matters which way they flow,  on my 1000 ltr cubies i fit the male part so its easier to connect the female part.
cheers stuart
just keep it simple
« Reply #4 on: December 07, 2013, 08:57:41 AM »
I suspect it only matters if they include a valve to stop flow. I use them on the processor and have them both ways round. Mine have no stop valves in them and have been in use for about 6 years with no probs.
« Reply #5 on: December 07, 2013, 09:11:06 AM »
I thought that it would be simplest to have a 'rule' whereby all hoses have male fittings (on both ends) and all pumps (etc) have female fittings (on both ports)
Id rather keep the male fittings on the hoses, as they do not have clips on them - so less to catch on stuff / get damaged (etc)
Oily bits sell the fittings in alluminium, but id rather some other material.  Anyone know anywhere cheap to buy them? (in 1" size)
Offline Bill
« Reply #6 on: December 07, 2013, 02:53:21 PM »
Try Intrico, they do lots of sizes in aluminium, stainless steel and polypropylene
Both sold
Offline thewormman
« Reply #7 on: December 22, 2013, 09:44:33 AM »
Only just seen this I use these people, fast delivery
http://www.ebay.co.uk/itm/111012522387?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
« Reply #8 on: December 22, 2013, 04:57:58 PM »
Flippin' 'eck, talk about Expensive.
He's charging 30% more than 316 stainless fittings for plastic ones, no wonder he has free postage.
You get well ripped off first then he does you a favour by offering free postage, bloody conman.
« Reply #9 on: December 24, 2013, 10:55:13 AM »
So, can you tell me where i can get a 1" type B, in stainless, for £6.94, less the 30%?
« Reply #10 on: February 13, 2014, 03:13:42 PM »
Bumping this, as im to buy some soon - where's this cheap supplier then, Jim?
Offline jkis
« Reply #11 on: February 14, 2014, 07:16:19 AM »
i used the alloy ones, they were a $1than the plastic for the small fittings the saving got beter as the size increased
cheers stuart
just keep it simple
