Welcome,
Guest
. Please
login
or
register
March 27, 2026, 01:31:11 AM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
Biodiesel
Biodiesel equipment
pump leaking
« previous
next »
Print
Pages: [
1
2
Author
Topic: pump leaking (Read 7123 times)
alifreddy
Impeller jammer
pump leaking
on:
September 22, 2013, 09:30:06 AM »
after using my processor for about a month the pump is leaking when I turn it on to circulate bio. it looks like its coming out of a little hole.
It leaks only a little. I put a bucket under to collect and is pumping most of the liquid around. I had some solid jelly type koh in the bottom of processor after last batch so I put a litre or 2 of methanol in the processor then drained it off.
Logged
Tony
Administrator
Oil baron
Fo' shizzle, biodizzle
Re: pump leaking
Reply #1 on:
September 22, 2013, 09:59:29 AM »
Sounds like the shaft seal has failed. What pump is it?
Logged
alifreddy
Impeller jammer
Re: pump leaking
Reply #2 on:
September 22, 2013, 12:53:58 PM »
not sure can take a pic all numbers rubbed off
Logged
alifreddy
Impeller jammer
Re: pump leaking
Reply #3 on:
September 22, 2013, 06:49:21 PM »
can it be repaired and will it get worse want to make enough bio between now and end of october so not making bio in colder months
Logged
julianf
Wiki Editor
Grand Gunge Master
Re: pump leaking
Reply #4 on:
September 22, 2013, 08:25:44 PM »
an unknown pump, with an unknown fault?
can it be repaired, and will it get worse?
best guess - unknown.
Logged
For custom cnc cut instrument panels, see -
http://www.thebeast.co.uk
Collections website -
http://www.devon-used-cooking-oil-collection.co.uk
Jmg
Wiki Editor
Impeller jammer
Another Fine Product From The Nonsense Factory
Re: pump leaking
Reply #5 on:
September 22, 2013, 09:32:20 PM »
My best guess is
1 possibly
2 probably
3 unlikely
Logged
Rampant automobile serial killer.
Currently torturing a 2.5 Mitsubishi Challenger on b100, not dead yet
Tony
Administrator
Oil baron
Re: pump leaking
Reply #6 on:
September 23, 2013, 12:08:43 AM »
In this case your best bet is to have it apart to see which seal is leaking and replace it.
Logged
alifreddy
Impeller jammer
Re: pump leaking
Reply #7 on:
September 23, 2013, 12:06:05 PM »
showed pump to my builder and he said its just a gasket. so we will take it apart and maybe just make a gasket he said
Logged
BANDIT2
Impeller jammer
Re: pump leaking
Reply #8 on:
September 23, 2013, 01:39:52 PM »
Doupt it but good luck.
Logged
Running [if I get enough veg] Defender 200TDI and Winnebago Lesharo (now gone)Range Rover P38 ,and a space heater on home made bio.
therecklessengineer
Administrator
Oil obsessive
Re: pump leaking
Reply #9 on:
September 23, 2013, 02:05:38 PM »
A photo of said pump, with a closeup of the leaking bit would enable us to diagnose it properly...
Logged
Waste oil collection in Somerset
whatarascal
Wiki Editor
Oil stirrer
If at first it dont work zod it
Re: pump leaking
Reply #10 on:
September 23, 2013, 03:13:47 PM »
I reckon the builder will probably know best
Logged
One day its all gonna go off
willbuild
Valve head
350 slc what i save on bio, I spend on this
Re: pump leaking
Reply #11 on:
September 23, 2013, 03:28:36 PM »
might have to agree with you.
Logged
oakwoodtv
Wiki Editor
Valve head
Re: pump leaking
Reply #12 on:
September 23, 2013, 03:47:25 PM »
Can we fix it yes we can
Logged
willbuild
Valve head
Re: pump leaking
Reply #13 on:
September 23, 2013, 07:49:46 PM »
did i mention that i'm a builder. got some no more nails in the van, that will fix it
Logged
Rotary-Motion
Wiki Editor
Oil baron
Re: pump leaking
Reply #14 on:
September 23, 2013, 08:18:39 PM »
i once sealed a leek in a petrol tank with nail varnish
Logged
Print
Pages: [
1
2
« previous
next »
Biodiesel
Biodiesel equipment
pump leaking
