Author Topic: New WVO Dewatering & Filter set up page.  (Read 41972 times)
« Reply #30 on: June 13, 2011, 11:16:43 PM »
5 now 4 + 1 guest
« Reply #31 on: June 13, 2011, 11:18:02 PM »
ok the main page!
need to change/edit title so it says
Processor - 3 in 1
not what it is now!
« Reply #32 on: June 13, 2011, 11:24:04 PM »
also just put right bottom pics you had 2x gallerys inside 1x gallery wasnt quite like above layout
all good now!
yehaaaaaaaaaaaaaa
« Reply #33 on: June 13, 2011, 11:30:58 PM »
Page looks good.  I'll try and catch up with the diagrams.
Keith ...
If you let me know the URL, I'll lift the float switch photo without the Reaconverter stamp.
« Reply #34 on: June 13, 2011, 11:36:36 PM »
check these bad boys out!
http://www.fluidswitch.com/
« Reply #35 on: June 13, 2011, 11:38:39 PM »
Ive got it in photobucket ok,it was when i had to convert to upload,used up my free trial :(
« Reply #36 on: June 13, 2011, 11:49:35 PM »
Ooo, it's very small.  Did you resize it?
« Reply #37 on: June 14, 2011, 12:22:40 AM »
« Reply #38 on: June 14, 2011, 12:32:27 AM »
pic changed!
 ;D
« Reply #39 on: June 14, 2011, 12:37:45 AM »
Do those float switches survive long term gunking up with crusty WVO?
« Reply #40 on: June 14, 2011, 11:22:12 AM »
It was recommended by Vince who's had no problems so far
« Reply #41 on: June 14, 2011, 08:02:50 PM »
at the position that is, if it were in my system, that would be very clear/clean oil level section, so all good to go
« Reply #42 on: June 15, 2011, 08:32:46 PM »
Juliain,me and RM have added a dispensing part to it now so how about "processor 3 in 1" ?
I will add a relevent piccy at the weekend
Its only for the wvo as the bio would be dispenced from its wash tank/tower
The outlet to car,from the bottom filter will have a tee in it going to the pipe from the top filters to settling tank,inline will be a pressure valve so when you release the trigger the valve will divert the oil back into the settling tank,if you follow :) its cost just under £25 so worth doing i think
Ok, best I hold fire on the graphic until I get details of the dispenser.  Have you thought of adding wheels and a draw bar?  Then you could tow it on your collection round and call it a 4 in 1.
But no, hang on ... if you added a fryer and rented it to the pub you could have a 5 in 1, the possibilities are endless!
« Reply #43 on: June 15, 2011, 08:57:54 PM »
lol  ;)
« Reply #44 on: June 16, 2011, 09:30:49 AM »
Mmm, chips with a hint of biodiesel, my favourite  ;D
