Author Topic: New WVO Dewatering & Filter set up page.  (Read 41973 times)
« Reply #15 on: June 11, 2011, 05:34:48 PM »
Bloody armatures.
Let them build processors without condensers and eductors and look what happens!
« Reply #17 on: June 11, 2011, 06:24:28 PM »
Ooops! That'll be the spell checker and my lack of attention!
I hope my mistake didn't detract from the very serious point I was making!
« Reply #18 on: June 11, 2011, 07:19:07 PM »
Armature indeed!,its alright for you lot that have got nothing better to do than watch a few pennies drop into a jar for hours
Now to be serious (this will only happen once)
No reason a condenser cant be fitted,just move the breather to the lid?
a venturi should work although the pipework contains tight bends to keep everything close in
BUT if you are just making a crud batch every 300/400 lts of good oil is it worth it? more batches and i imagine  you would make dedicated processor?
Eductor,cant see why not
BUT you would be limited to making the same size batch everytime and as this would be crud i personally would 2 stage it,then an eductor is useless
Inline heater,sorry thats a definate no-no,as its primarily a filtering set up the heater needs to be in the tank so that you can heat without circulating
Squirrel? now your just taking the yellow stuff!
« Reply #19 on: June 11, 2011, 09:12:45 PM »
I detect a theme here?
Have to agree with your reasoning in respect of multi tasking processor though.
« Reply #20 on: June 13, 2011, 10:21:06 PM »
Juliain,me and RM have added a dispensing part to it now so how about "processor 3 in 1" ?
I will add a relevent piccy at the weekend
Its only for the wvo as the bio would be dispenced from its wash tank/tower
The outlet to car,from the bottom filter will have a tee in it going to the pipe from the top filters to settling tank,inline will be a pressure valve so when you release the trigger the valve will divert the oil back into the settling tank,if you follow :) its cost just under £25 so worth doing i think
« Reply #21 on: June 13, 2011, 10:42:44 PM »
i class it as wvo and bio now its made and piped for it and thirdly dispensing so yes a 3 in 1 system
so good to go in both bio and veg side links (which i done)
i cant seem to get it on main page???
tried ncl links on page no joy
« Reply #22 on: June 13, 2011, 10:57:48 PM »
Paul, there's a small quirk with the NCL script ... to get a new page to list automatically you have to go into edit on the main page and click save without changing anything.
Obviously the new page must have categories or NCL won't know how to list it.
« Reply #23 on: June 13, 2011, 11:00:42 PM »
Hav,nt got a clue what you two are on about but 3 people on line WEEEEEEEEEEEEEEEEE
« Reply #24 on: June 13, 2011, 11:06:07 PM »
Just noticed you only have major categories on the page .. veg and Bio.
Leave those on the page and try adding ...
[[Category:Processors and equipment]]   and   [[Category:Filtration & drying equipment]]
Then edit and save the main page.
Is three a record!  Let's have a party!
« Reply #25 on: June 13, 2011, 11:08:15 PM »
Look, you scared RM off and spoiled the moment.
« Reply #26 on: June 13, 2011, 11:09:17 PM »
He will be back-like a bad smell ;D
« Reply #27 on: June 13, 2011, 11:13:41 PM »
im fricken here hahahaaaaaaaaa 8)
« Reply #28 on: June 13, 2011, 11:15:27 PM »
4 now, i feel faint!
« Reply #29 on: June 13, 2011, 11:15:35 PM »
all done in main page now!
thx chap....
