Author Topic: New WVO Dewatering & Filter set up page.  (Read 45416 times)
« on: May 29, 2011, 06:04:49 PM »
Great page, but it not getting indexed on the main page because it has no categories ...
[[Category:Vegetable oil]]
[[Category:Filtration & drying equipment]]
Would do it.
« Reply #1 on: May 29, 2011, 08:20:37 PM »
Its not finished so i dont want it "live" yet
Its now a dual processor
« Reply #2 on: May 30, 2011, 09:56:48 AM »
Oh, sorry I didn't know!
I already linked to it from a page I posted ... Do you want the link removed?
« Reply #3 on: May 30, 2011, 10:36:39 AM »
No thats ok,whats there is fine but with a bit of help from RM, Nige and Vince ive made it so it can also make bio although it will be a very "basic"  ;D design and there are a couple of suggestions ive yet to implement.
It started as a filter set up with bypass but then i decided it was not that far from a processor and i thought it would be of use to guys who filter but are left with crud,so say every 500 litres of filtered they could do a batch of bio so they can use 100% of whats collected,good idea or not?
It will need a title change at some point is that possible?
« Reply #4 on: May 30, 2011, 11:46:38 AM »
Yes completely possible. What new title do you want?
Happy to alter the original processor page you did too, I was just under the impression that you had agreed with the changes at the time!  The second tank on that system struck me as a wash tank which would make the basis for a separate page, allowing people to add it to either a 'GL' or a 'proper processor if they wished.
Happy to do a graphic similar to the existing processor graphics for your current page if you wish.
« Reply #5 on: May 30, 2011, 08:26:56 PM »
Dual processor maybe? or open to suggestions,anyway no hurry until ive amended the page
Graphics would be great,probably need two? one to cover each process?
With the basic page it was just something i noticed when i reread it,
ive just looked again and i suppose the only thing wrong with the pic is the label "240lpm pump"can that be removed?
Do you see how i was reading it? ie
the basic processor includes a 240 lpm pump then it can be upgraded with a bigger pump and eductor,i didnt want people thinking it needs a 240 pump to start with and if they added to it the bio would be ready 5 mins before they put it in :)
Just a thought maybe label it "basic with upgraded pump" that would explain it
« Reply #6 on: June 01, 2011, 05:34:55 PM »
I think I get where you are coming from.  Is this photo better?
http://www.biopowered.co.uk/wiki/File:Modified_KH_processor.jpg
« Reply #7 on: June 01, 2011, 06:07:55 PM »
Spot on  :)
« Reply #8 on: June 01, 2011, 06:29:26 PM »
Goodo.
 If you want to swap the two, just replace the original file name with ...
« Reply #9 on: June 08, 2011, 10:59:35 PM »
Page is nearly done now,ive made a batch of bio to check it out,i will ask RM to add some links and rearrange the bottom pic
Julian
How does "dual processing system" sound?
And could i take up your offer of graphics and email you a really rough sketch of the valve workings?
« Reply #10 on: June 08, 2011, 11:30:38 PM »
Happy to do graphic.   My email address is listed on both forums. If you want a "state diagram", can you include an operation sequence too.
Naming is entirely up to you, but a suggestion would be "Processor - dual function" to keep it in line with existing pages.
I hesitate to suggest anything more basic!
« Reply #11 on: June 10, 2011, 01:42:05 PM »
E mail sent,your address on here is "hidden" to me :(
Processor/filter station-dual function-is that in keeping?
« Reply #12 on: June 10, 2011, 09:28:19 PM »
Got the email, but I really can't see it working ... there's no condenser!
« Reply #13 on: June 10, 2011, 11:07:41 PM »
I keep it in the same place as the eductor-The bin!
Just found a major flaw with mine,pumping out finished bio is a wee bit difficult with a float switch on the pump!  :-[
In the plans its connected to the imm but i had fitted one to the pump when it was just going to be a filter set up
« Reply #14 on: June 11, 2011, 05:19:28 PM »
hmm yes didnt think on total pump out for bio, a veg only system keeps oil level in crud zone forever after first fill over the heater element so all good there....
