Welcome,
Guest
. Please
login
or
register
October 26, 2025, 08:20:56 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
Biodiesel
Biodiesel equipment
ph of bio diesel 9.8 tds ppm 0
« previous
next »
Print
Pages: [
1
2
Author
Topic: ph of bio diesel 9.8 tds ppm 0 (Read 7113 times)
alifreddy
Impeller jammer
on:
August 26, 2013, 08:22:35 PM »
runs like its starving of fuel at over 2500 rpm in 3rd seems to be more even and ok at high revs with a splash of petrol 2-3 litres per 40 litres of bio in my van
Its a Vauxhall combo 1.7 di done 223k 20 k mostly on svo and dino diesel only recently started using bio due a to a filter or tank filter blockage
Logged
greasemonkey
Wiki Editor
Grand Gunge Master
Re: ph of bio diesel 9.8 tds ppm 0
Reply #1 on:
August 26, 2013, 08:39:50 PM »
If you have recently started using Bio, then you almost certainly will experience a fuel filter blocked. Took me 100 miles. Now it blocks every 350, so I guess it's moved a lot of crap off the walls of the tank.
Start by changing the fuel filter.
Logged
alifreddy
Impeller jammer
Reply #2 on:
August 26, 2013, 08:41:18 PM »
on its fourth brand new filter. done about 1000 miles
Logged
alifreddy
Impeller jammer
Reply #3 on:
August 26, 2013, 08:44:30 PM »
this was bio made in a converted copper hot water tank that used to get very hot just had a tap at the bottom with pipework from the bottom of tank works ok without circulating heated bio round.
I'm just letting another batch I made in my etruk 100 react heated for 1 hour after glyc washing. did 75 litre batch added 14 litres methanol and 640 gs of koh see how it comes out tomorrow
Last Edit: August 26, 2013, 08:57:11 PM by alifreddy
Logged
greasemonkey
Wiki Editor
Grand Gunge Master
Reply #4 on:
August 26, 2013, 08:46:22 PM »
Quote from: alifreddy on August 26, 2013, 08:41:18 PM
Same here. It's still blocking 'um, and I only put 100 litres of bio in it.
Logged
alifreddy
Impeller jammer
Reply #5 on:
August 26, 2013, 08:58:47 PM »
am dry washing in hardwood saw fine dust. encouraging to see tds at 0 but still wanna try ion exchange resin as it claims to convert soap to free fatty acids but with a reading of 0tds there is no soap in it??
Logged
alifreddy
Impeller jammer
Reply #6 on:
August 26, 2013, 09:01:55 PM »
added a bit of distilled vinegar to bring ph down to just 1 25 litre drum of dry washed bio
Logged
Julian
Administrator
Oil baron
Reply #7 on:
August 26, 2013, 11:14:08 PM »
This TDS meter, new to me , Googleing reveals that it measures dissolved solids in water. Is it viable for biodiesel?
And how are you measuring the pH of your bio?
Logged
Used Cooking Oil Collection website ...
http://www.surreyusedcookingoilcollection.palmergroup.co.uk
alifreddy
Impeller jammer
Reply #8 on:
August 26, 2013, 11:15:38 PM »
a ph meter pen
Logged
alifreddy
Impeller jammer
Reply #9 on:
August 26, 2013, 11:17:23 PM »
also a tds metre pen
Logged
julianf
Wiki Editor
Grand Gunge Master
Reply #10 on:
August 26, 2013, 11:48:04 PM »
Quote from: alifreddy on August 26, 2013, 11:15:38 PM
a ph meter pen
One that is not designed to work with Aqueous solutions?
Logged
For custom cnc cut instrument panels, see -
http://www.thebeast.co.uk
Collections website -
http://www.devon-used-cooking-oil-collection.co.uk
alifreddy
Impeller jammer
Reply #11 on:
August 26, 2013, 11:53:24 PM »
only started making bio diesel again and wanted to test it . I've already done a water shake test just wondered if there was anything wrong with my bio that's making my van run funny
I was running my van on wvo so that may be a factor.
I'm still getting a bit of soap in water in shake test after dry washing but a lot less than when I tested at first before wash
Logged
Julian
Administrator
Oil baron
Reply #12 on:
August 27, 2013, 12:39:46 AM »
Hmm, I think the pH meter and TDS meter are probably a waste of time when it comes to bio.
I believe the way to test bio for pH is by titration. Similarly for soap try a titrated soap test ...
http://www.biopowered.co.uk/wiki/Soap_tests
NigelB on here sells the kits.
Have you cut open a filter to see what's blocking it?
Are you leaving the bio to settle for a week or so after manufacture, or just bunging it straight in the car?
Logged
therecklessengineer
Administrator
Oil obsessive
Reply #13 on:
August 27, 2013, 07:30:37 AM »
Yes - the above.
What are the results of the 50/50 test? Post up a photo if you can.
Logged
Waste oil collection in Somerset
alifreddy
Impeller jammer
Reply #14 on:
August 30, 2013, 12:39:30 PM »
here is a50/50 test of my latest batch of bio before dry washing quite soapy
https://www.facebook.com/photo.php?fbid=293098007495963&set=a.115291161943316.16830.100003872979703&type=1&theater
Logged
Print
Pages: [
1
2
« previous
next »
Biodiesel
Biodiesel equipment
