Welcome,
Guest
. Please
login
or
register
December 14, 2025, 02:04:28 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
Vegetable oil motoring
Vehicles
black clouds of smoke under heavy load
« previous
next »
Print
Pages: [
1
Author
Topic: black clouds of smoke under heavy load (Read 5225 times)
Rotary-Motion
Wiki Editor
Oil baron
on:
May 29, 2013, 03:16:27 PM »
hi all
maybe got the chance of a car that smokes like shizz under heavy load (acceleration / uphill)
what would you say is part of engine at fault?
any way of finding out?
car is a VW Passat 1.9TDI (non PD engine) 110bhp
Logged
knighty
Wiki Editor
Oil obsessive
Re: black clouds of smoke under heavy load
Reply #1 on:
May 29, 2013, 03:38:53 PM »
black smoke normally means a bad fuel-air mix
check the air filter first
make sure it's black smoke and not blue - check the oil
also, is it only when you push it really hard ? - someone could have tuned up the max fuel on the pump :-o
Logged
Tony
Administrator
Oil baron
Fo' shizzle, biodizzle
Reply #2 on:
May 29, 2013, 04:27:47 PM »
Might be EGR jammed open on grime? Amazing how black the smoke is if the EGR is open.
Logged
Rossey
Wiki Editor
Valve head
Reply #3 on:
May 29, 2013, 05:13:33 PM »
Rolling coals
Mines does it but i have up'd the fuelling
Logged
Dickjotec
Wiki Editor
Oil obsessive
Reply #4 on:
May 29, 2013, 05:22:54 PM »
RM totally off topic but I have just put the first experimental HE in the hot tub.
Logged
Bio since 2007 running Delica and Octavia
Rotary-Motion
Wiki Editor
Oil baron
Reply #5 on:
May 29, 2013, 08:30:52 PM »
Quote from: Dickjotec on May 29, 2013, 05:22:54 PM
nice one dick....
and to all other users advice i wll look into it more... with whats been said
Logged
Rotary-Motion
Wiki Editor
Oil baron
Reply #6 on:
May 31, 2013, 05:38:35 AM »
quick update
stood still revved upto 5500 rpm (flat out scare the neighbours) on revving up smokes black abit now and flat out no smoke if you hold engine there foot to floor...
Logged
Rossey
Wiki Editor
Valve head
Reply #7 on:
May 31, 2013, 07:29:19 AM »
If it smokes while boosting under load, I would think its the boost pressure sensor thinking the pressure is higher than it is.
Have you unplugged the maf to see if that makes a difference?
Logged
Rotary-Motion
Wiki Editor
Oil baron
Reply #8 on:
June 01, 2013, 04:55:42 PM »
maf?
Logged
1958steveflying
Wiki Editor
Oil obsessive
Reply #9 on:
June 01, 2013, 09:36:49 PM »
Quote from: Aliis volat propriis on June 01, 2013, 04:55:42 PM
maf?
maf = Mass air flow sensor
Located between the air filter box and the intake, unplug it and the ecu will run at default settings so may indicate an issue with it if the problem goes away when unplugged.
Logged
Rossey
Wiki Editor
Valve head
Reply #10 on:
June 01, 2013, 10:24:52 PM »
If that sorts it you can just put a diode in the plug
Google vw maf mod
Logged
RichardP
Wiki Editor
Impeller jammer
Reply #11 on:
June 02, 2013, 09:09:34 AM »
Is it making any odd noises when under load and smoking?
When under load and smoking does it feel gutless?
Could be a split turbo hose or intercooler, that could cause overfueling and smoke, and make it feel sluggish.
Logged
Rotary-Motion
Wiki Editor
Oil baron
Reply #12 on:
June 02, 2013, 10:11:19 AM »
hi guys
thanks for that its all being noted, not had chance to look at it yet, my neighbour should be back today and we need to sort a flat tyre that appeared also.
this version of a vw passat is an auto gearbox...
Logged
nigelb
Wiki Editor
Grand Gunge Master
Reply #13 on:
June 02, 2013, 04:23:48 PM »
The black smoke could be a split pipe from the intercooler to the inlet manifold. I had an issue with my 90hp engine a couple of years ago. I could hear something odd like air escaping under load, and it used to smoke real bad. Turns out it was the rubber hose just before the inlet manifold had split slightly but on the underside of it. Worth checking!
Logged
Print
Pages: [
1
« previous
next »
Vehicles
