Author Topic: ***Looking at Methanol recovery***  (Read 6888 times)
Offline RIngrey
« on: March 04, 2011, 02:43:24 PM »
My processor doesn't support methanol recovery. As I have plenty of Glycerine (Potassium based) I'm looking at recovering the methanol if possible. I was looking at buying a small still so that I could distill the meth from the glycerine. Would this work? ???
Re: ***Looking at Methanol recovery***
« Reply #1 on: March 04, 2011, 02:45:51 PM »
Have you done any water prewashes IE contaminated the glycerol with water?
Offline RIngrey
« Reply #2 on: March 04, 2011, 06:45:28 PM »
No prewashes as I seem to produce good results without doing it. So my glycerine is uncontaminated with water.
« Reply #3 on: March 04, 2011, 07:39:16 PM »
You should be good to go on recovering Meth from the Glycerol then :)
Offline RIngrey
« Reply #4 on: March 05, 2011, 02:32:49 AM »
Will a Still do the job?
« Reply #5 on: March 05, 2011, 09:31:32 AM »
Yes, but it might just be easier to add a condenser to your processor and heat it in that (assuming it's not plastic?)
You don't need a venturi for it to work, you'll still collect the Meth - though this could be speeded up by bubbling air through it.
Offline hifly
    • waste oil devizes
« Reply #6 on: March 06, 2011, 01:05:32 PM »
if you are in the uk you will find it difficault to buy a still as they are ilegal to sell, i made one from a berco boiler to de-meth my glyc, i fitted a bubbling ring in the bottom to force ait through the condencer. worked fine.
VW T4 2.5Tdi
« Reply #7 on: March 06, 2011, 02:53:57 PM »
Hifly stills are readily available on ebay,they get around the law by saying "for distilling water"
http://cgi.ebay.co.uk/Smart-Still-Still-Spirits-Distillation-unit-/110565063299?pt=Home_Brew&hash=item19be30fa83
« Last Edit: March 06, 2011, 06:35:02 PM by KH »
« Reply #8 on: March 07, 2011, 10:52:09 AM »
The more I hear about bubbling air in being an effective way to push off the Meth, the more I want to try it on my processor to see if it speeds demething up.
It makes sense pushing an air bubble all the way up through the liquid you want to Demeth, which will also help with agitation.
Offline Stumpy
« Reply #9 on: November 14, 2013, 10:00:25 AM »
I always bubble air in through the drain on my processor, it speeds up the methanol reclaim vastly on my plant.
Titless process
WBD
Hardwood polish
Free Hardwood shavings/sawdust if collected.
« Reply #10 on: November 14, 2013, 11:53:50 AM »
I tried bubbling from the processor, through the condenser using a small compressor, for quite a time.  It worked very well, nearly doubling what I can distill with the venturi and sometimes over loading the condenser.
I had problems, however, in humid weather, as the recovered methanol appeared to be absorbing the moisture from the in coming air.
A water trap on the air line made no difference and I got half way through making a desiccant dryer, but the resistance through it was quite high and drying the desiccant would have been a pain, so I reverted to using the venturi.
« Reply #11 on: November 14, 2013, 02:18:23 PM »
That's where a Squirrel excels, rapid demeth and no moisture drawn in, add a still head heat exchanger and the condenser can cope with a greater volume of vapour for less energy input.
« Reply #12 on: November 14, 2013, 03:55:21 PM »
I tried a Squirrel and mine certainly didn't excel!
« Reply #13 on: November 14, 2013, 05:09:06 PM »
And by your own admission neither do your Venturis so me reckons your opinion on Squirrels should be discounted.
« Reply #14 on: November 14, 2013, 07:08:36 PM »
Did I express one?
