Author Topic: How small can make a processor?  (Read 7995 times)
Offline Rossey
« on: April 29, 2013, 09:05:57 PM »
I wanna make bio diesel for my start up tank, which is only 20 litres.
I have two 20 litre clip top drums
Is it possible to make a 20 litre processor?
What heating element could I use?
Re: How small can make a processor?
« Reply #1 on: April 29, 2013, 09:18:10 PM »
A standard 11" heater will fit, heres one i made for demo purposes
« Reply #2 on: April 29, 2013, 09:19:45 PM »
very nice kieth
« Reply #3 on: April 29, 2013, 09:21:06 PM »
I think that Dickjotec has something similar for tutorial purposes
« Reply #4 on: April 29, 2013, 09:35:05 PM »
I've been thinking about building a baby reactor as well, but for testing purposes.
I was talking to Julian about it only yesterday.
But I need to see how my current situation pans out.
« Reply #5 on: April 29, 2013, 09:48:48 PM »
If you have a stainless 10l stockpot you could heat oil in that then pour into a 25l drum (from your local car wash - free!) then add the chemicals and shake up every now and again.
Making biodiesel can be simple.  Making good biodiesel - well, that might take a bit more - but we can definitely help you there :)
« Reply #6 on: April 29, 2013, 09:51:44 PM »
do it chug styly, kick it round the drive
 ;D
« Reply #7 on: April 29, 2013, 10:45:21 PM »
I have a fully functioning 30ltr 3 tank system with all the bells and whistles to boot.
It was built for demonstration purposes, it's done a few batches now.
« Reply #8 on: April 29, 2013, 11:24:55 PM »
Yes I have a small processor that I use to demonstrate. Works well enough. I used a kettle element, mainly as I had one. I comes apart so each piece can be handled and discussed and then be fitted and seen functioning.
Dick
Offline Jmg
    • Veg site
« Reply #9 on: April 30, 2013, 09:37:41 AM »
That's the method on YouTube, the supersized Dr pepper method. I'm tempted to do that with my leftover sludge from filtering, either that or hoard them til I finally build a processor or more likely they evolve and walk out on their own.
Offline Rossey
« Reply #10 on: April 30, 2013, 01:52:56 PM »
I like the kiss method  ;D
I've had an idea
If I use a 25lt car wash job, with some kind of element through the bottom.
Strap it to a wheel with a handle so I can spin it.
I can pour the meth in outside (I'm worried about fumes) :o
Then I can fit a tap to the lid leave it to settle upside down to drain the soap off.
Stick some water in through a fitting in the bottom and bubble it.
Straight out the bottom fitting through a sock and hey pesto.
Why you lot think?
« Last Edit: April 30, 2013, 01:57:57 PM by Rossey »
« Reply #11 on: April 30, 2013, 03:16:59 PM »
I wouldn't fancy sticking a heater element in a plastic 25litre drum  :o
to save yourself the hassle... is there no-one close to you who make bio, which you could swap some oil for ?
unless you just want to do it for fun/experiment/hobby... then I'd try to get one of those 10gallon metal buckets and build it inside there...
do you de-water your oil ? you could always heat your oil first, then put it in a well insulated reactor... it should stay hot enough to react ?
« Reply #12 on: April 30, 2013, 03:48:54 PM »
My smallest batch was 500ml and it passed a 3/27, did it on a magnetic stirrer.
« Reply #13 on: April 30, 2013, 05:03:28 PM »
Pah, that's nothing ... me and womble did a 40ml, single stage, ASM batch with soap feed stock at the weekend.
EDIT ... correction, just checked and it was 20ml in a 40ml tube... EDIT
« Last Edit: April 30, 2013, 05:49:53 PM by Julian »
« Reply #14 on: April 30, 2013, 05:52:01 PM »
i did one size of a pin head
 ;D
