Author Topic: How small can make a processor?  (Read 7994 times)
Re: How small can make a processor?
« Reply #15 on: April 30, 2013, 06:00:32 PM »
i did one size of a pin head
I heard that too.  But I don't think we're talking about the same thing.
« Reply #16 on: April 30, 2013, 06:13:20 PM »
 ;D
Why so large, I made a complete tank full inside the eye of a needle, mind you it was a small tank.
I'm gonna try a batch on the back of a single bacteria.
« Last Edit: April 30, 2013, 06:40:44 PM by Jamesrl »
« Reply #17 on: April 30, 2013, 07:29:22 PM »
im going to do all that but in a matchbox while going backwards on the m25
« Reply #18 on: April 30, 2013, 08:00:06 PM »
This is an interesting twist on the usual "Who's biggest".
Offline Rossey
« Reply #19 on: April 30, 2013, 08:00:46 PM »
I wouldn't fancy sticking a heater element in a plastic 25litre drum  :o
to save yourself the hassle... is there no-one close to you who make bio, which you could swap some oil for ?
unless you just want to do it for fun/experiment/hobby... then I'd try to get one of those 10gallon metal buckets and build it inside there...
do you de-water your oil ? you could always heat your oil first, then put it in a well insulated reactor... it should stay hot enough to react ?
I have a new friend to make bio for me,
Just wanted something to play with
I do dewater, so i can just fill it with hot oil.
What a stirring paddle to mix it.
I could mount it through the lid on a bearing block.
And put a drain fill on the bottom to drain soap and fill with water for bubbling
« Reply #20 on: April 30, 2013, 09:03:56 PM »
Done that but on a high wire whilst riding uni-cycle sideways up the entire length of the M6.
When I get me new specs I'm gonna take a single triglyceride molecule, pull the glyc particles off the hydrocarbon chains and glue 3 methanol bits on with arldite.
So there.
« Reply #21 on: April 30, 2013, 10:37:25 PM »
So there.
all that then set fire to it, watch that sucker go... while sleeping, sipping a banana milkshake, upside down, inside out and back to front
 :o
« Reply #22 on: May 01, 2013, 12:52:59 AM »
So there.
 :o
Aha! caught you out now 'cause you can't sip a milk shake upside down AND inside out at the same time, well not according to the first law of thermodynamics you can't.
« Reply #23 on: May 01, 2013, 06:36:15 AM »
some laws can be broken
Offline tiamaria
« Reply #24 on: May 01, 2013, 10:51:38 AM »
on a unicycle
« Reply #25 on: May 01, 2013, 10:04:06 PM »
 ;D ;D ;D
