Author Topic: Carver cascade 2 gas water heater boiler propane butane  (Read 17097 times)
Re: Carver cascade 2 gas water heater boiler propane butane
« Reply #30 on: April 18, 2013, 10:28:18 PM »
this make it 85c non adjustable i think? replacement stat
dodgy as at 90c the wax emegency plug will melt and shower water on the burner
http://www.ebay.co.uk/itm/Carver-Cascade-2-Water-Heater-GE-Heater-Element-Manual-Thermostat-/180942016635?pt=UK_Campervan_Caravan_Accessories&hash=item2a20fc107b
My rother changed his stat, they're a standard type unit ad ca e brought i different temps.
Offline chariot
« Reply #31 on: April 18, 2013, 10:31:19 PM »
I have a plan for 'central heating' setup in a big Merc van I may buy - in my head. It would be simpler than the cascade setup and have dual purpose. Also much cheaper to run. It was inspired by the vod postings a few years ago about the Sprinter van with the large veg oil tank between the front seats as mentioned above.
For a start, the van would be very well insulated so heat losses were minimised. The heating bit would be a water tank in the middle of the van. It would have a very well-insulated cover in sections so that when the water is hot, the heating could be adjusted.
A hot tank (say 70-80C) would be sized - through trial and error with intelligent guestimates - sufficient to keep the van from getting uncomfortably cold in the small hours. It would be heated by the engine via a fphe when the vehicle was running, with a 12v pump to circulate the heating tank water. I've no idea how long it would take for 60 litres of water to heat up to 60C at 60mph, I would try it and see.
The tank's dual purpose would be that when the heated tank wasn't needed for heating, the insulation cover would stay on and the next morning there would be plenty of heat left. With an underbonnet 12v pump running in the engine cooling system and by circulating the tank of hot water through the fphe, the engine could be preheated.
I have done no calculations, it is purely a thought which one day I will try out.The heated tank could also provide shower and washing water. It could also have a circuit to heat the fuel tank, potentially creating a vehicle which could run (twin-tanked) on lard.
A really small log burner/rocket stove would also make sense if you were planning on sub-zero camping or when daylight hours are very short. Waste heat from this could heat the water tank via a copper coil and a bit more pipework.
In theory this could give you a vehicle which had its engine and fuel tank pre-heated by wood.
« Last Edit: April 18, 2013, 10:33:50 PM by chariot »
« Reply #32 on: April 18, 2013, 10:36:40 PM »
there is some very nice ideas there fo sho, but dam it would be alot of pipes / wires.
K.H gave me a 12v heater i think 500 watts i willtry find a picture
Offline chariot
« Reply #33 on: April 18, 2013, 10:39:56 PM »
The Carver Cascade I removed from an ex-gf's caravan had lots of pipes and wires too! 15mm copper, fphes, car coolant system hoses and gate valves I understand - not sure I could explain everything on a cascade, let alone easily and quickly mend one!
« Reply #35 on: April 18, 2013, 10:42:58 PM »
water in / out pipe
gas pipe
12v
switch
and flue out of van
oh and 240v if you have that model
Offline chariot
« Reply #36 on: April 18, 2013, 10:50:15 PM »
Aye, well this one had an electronic control unit, pressurised lpg supply, 240v, plumbing fittings which I've never seen before, which broke very easily, etc. Sure, nothing too impossible but I'd prefer a water tank and a fphe supplied bywith a coolant loop from the engine, with a 12v water pump in the system. Nice robust connections, ubiquitous fittings etc.
But I agree, there'd be more pipework length than with a carver, which would have to be carefully insulated.
« Reply #37 on: April 18, 2013, 10:56:01 PM »
oh ye all doable for sure on your idea, was gonna have simarlar on my day van, engine heat a tank for hot water, i already got a twin tanked van on veg, even got the fphe ready to install, but to many pipes under van bonnet already fo me... i already have a space heater off the van coolant between the front seats for your ideas and T off for the fphe inside the van... oh yes im on your wave length
« Reply #38 on: April 18, 2013, 11:03:21 PM »
ok everyone have a look at this pic, does that look like that whale pressure switch is setable on pressure?
it looks like a turn down screw on the top
if so i could use that to turn down my 30 PSI pump to 20 PSI/1.4bar then use my already fitted tank to pull cold feed into heater, hence getting hot AND cold running water...
Offline chariot
« Reply #39 on: April 18, 2013, 11:04:33 PM »
Agree, don't like too much stuff under the bonnet. Never yet twin-tanked, even though have had the 3-way valves sat on the shelf for years! Cascades are compact and deliver the goods, but if you're going to have a wood stove in your van (which I think is a good thing - it means you're not reliant on 240v hook ups and lpg supplies or the cost of all that) it'd be a shame not to link it to a simple 'central heating' tank which could also be heated by your waste engine heat as well as pre-heat your engine.
Wish I was Vectra man, happy with a couple of crap foreign holidays. In some ways. But not many!
« Reply #40 on: April 18, 2013, 11:08:29 PM »
not too worried on 240v hookup as dont intend visiting a site much, maybe only to steal a shower or take a dump...
i plan pulling up wherever at any time, so 12v and gas is utmost, but i do have an inverter 1100watt in the van and a 1000watt genny / 12v battery charger
Offline chariot
« Reply #41 on: April 18, 2013, 11:11:45 PM »
Wood is free! So is the waste heat from your engine. Both can be gathered anywhere. LPG ain't and can't. But I take your point.
« Reply #42 on: April 18, 2013, 11:15:19 PM »
i hear ya for sure, forgot to add got split charger, 2x batts aswell just in case...
so chariot when you buying this van and get stuck in?  8)
http://www.biopowered.co.uk/forum/index.php/topic,748.0.html
« Reply #43 on: April 18, 2013, 11:23:55 PM »
Have you seen this?
http://deepredmotorhome.com/index.php
Quite an interesting read. Big budget campervan, some interesting writeups about the build. Not really relevant to what your doing, but worth reading.
Offline chariot
« Reply #44 on: April 18, 2013, 11:38:16 PM »
When is a good question. Two v young offspring and icy (Vectra-style, well-hidden on consumation) ex don't help. But one day there will be perfection in life for me  ;)
Btw, which 2.5 lump is it in your motahome?
