Author Topic: Carver cascade 2 gas water heater boiler propane butane  (Read 17274 times)
Re: Carver cascade 2 gas water heater boiler propane butane
« Reply #15 on: April 18, 2013, 07:49:50 PM »
have you thought about lpg instead ?
it's apparently really easy to convert stuff over to lpg, and then you can burry the tank wherever you like and fill up at the motorway services etc...
it's a bit more expensive than gas, but makes things easier if you don't need to get a bottle in/out, and it's not like you'll use a lot ?
(that's what I'm planning for mine)
also thinking about making myself a 'storage radiator' - just a tank of water to be heated via a FPHE when the engine is running... 100litres or so, I'll have it boxed in or covered up or something like that during the day, then on a night uncover it and it should give out some nice steady heat
can't remember his user name, but there's a guy on VOD who had an oil tank in the front of his sprinter between the seats... the surfer who goes all over the place, (maybe ski too?) to the alps etc...  anyway... he said with his tank of hot oil in the van there was never any ice on his van in the morning when everyone else's was iced up and covered in snow...  guess it's worth a shot!  (no noise too, I HATE any noise when I'm trying to get to sleep)
« Reply #16 on: April 18, 2013, 08:46:00 PM »
im sort of thinking maybe i dont need a rad? those carvers get quite hot tripping in and out, and i only need the chill taken off the van while sleeping as i will be under a duvet, i just dont like the cold damp feeling at 5 in the morning i wake due to it...
and basically just use for hot water in the morn to wash with and wash breakfast plates up
« Last Edit: April 18, 2013, 08:50:14 PM by Confucius »
« Reply #17 on: April 18, 2013, 09:14:11 PM »
Having problems with my key board, so this may e hard to read.
Why not put the tank i a ventilated ox ad leave the isolation off, the you ca leave it o all night ad keep the chill off the van.
« Reply #18 on: April 18, 2013, 09:17:59 PM »
Having problems with my key board, so this may be hard to read.
Why not put the tank in a ventilated box and leave the isolation off, then you can leave it on all night and keep the chill off the van.
Ooo! It's like fill in the blanks in a kiddys spelling book. Do I get a prize Mummy.
Can I have a sweety. :P
« Reply #19 on: April 18, 2013, 09:25:49 PM »
mark give GM a slap lol
« Reply #20 on: April 18, 2013, 09:27:06 PM »
Slap.
« Reply #21 on: April 18, 2013, 09:27:55 PM »
ventilated box is my bed, be under my bed / seat, so like an electric blanket  8)
will put vent holes in bed front plywood
« Last Edit: April 18, 2013, 09:31:12 PM by Confucius »
« Reply #22 on: April 18, 2013, 09:30:15 PM »
Slap.
Yelp!  ;D
« Reply #23 on: April 18, 2013, 09:31:58 PM »
Slap.
Yelp!  ;D
men beating on men is sexy
 :o
« Reply #24 on: April 18, 2013, 09:40:39 PM »
if i take the poly sty rene off it will let the heat out more  ;D
« Reply #25 on: April 18, 2013, 09:42:00 PM »
mark see that inline switch in that picture, what is that it for?
« Reply #26 on: April 18, 2013, 09:50:07 PM »
That's proaly set up as a pressurised system, pump comes o when that switch senses low pressure.
« Reply #27 on: April 18, 2013, 09:53:16 PM »
All this messing about ... just install a log burner.
« Reply #28 on: April 18, 2013, 10:10:17 PM »
Clarkso put one i a S class.
Dam keyoard  >:(
« Reply #29 on: April 18, 2013, 10:17:13 PM »
this make it 85c non adjustable i think? replacement stat
dodgy as at 90c the wax emegency plug will melt and shower water on the burner
http://www.ebay.co.uk/itm/Carver-Cascade-2-Water-Heater-GE-Heater-Element-Manual-Thermostat-/180942016635?pt=UK_Campervan_Caravan_Accessories&hash=item2a20fc107b
« Last Edit: April 18, 2013, 10:19:54 PM by Confucius »
