Author Topic: 27/3 test  (Read 3559 times)
Offline RIngrey
27/3 test
« on: February 14, 2011, 03:00:27 PM »
Carried out my first reaction at the weekend. I did the 27/3 test and had some fallout albeit only minimal. I have been assured that the bio will be OK to use without further reaction. However, how can I make sure there is no fallout in the next processed batch?
Re: 27/3 test
« Reply #1 on: February 14, 2011, 03:32:00 PM »
If you didn't do one, try a two stage reaction?
Works really well for me ... just done a batch of 30 litres, good oil 40 litres palm oil blend and 10 litres really grotty whites.  I got 2 litres of water out probably from the whites and had very minor (just noticeable in the bottom of a conical test tube) drop out which I consider acceptable.
Re: 27/3 test
« Reply #2 on: February 14, 2011, 03:36:17 PM »
Did you test with the Methanol at 20C?
A little dropout is OK, can you measure it?
If you've got 0.3ml of dropout from your 3ml of sample then the oil is very roughly 90% converted and this is fine for most vehicles.
Offline RIngrey
Re: 27/3 test
« Reply #3 on: February 14, 2011, 05:54:29 PM »
Probably even less than that if I'm honest. Conical bottomed test tube and about a millameter to a millameter and a half at the bottom. Don't know the temp of the methanol but definitely less than 20C.
Re: 27/3 test
« Reply #4 on: February 14, 2011, 07:09:26 PM »
In that case I really wouldn't worry about it  ;D  Your car will love it.
Re: 27/3 test
« Reply #5 on: February 15, 2011, 10:07:35 AM »
Ringrey,
if ya get 2-3 sample jars with 27ml meth in then add 0.5ml wvo to one, 0.25ml to another and 0.1ml to a third you can then compare them to future 3/27's and get an idea of the amount of fallout, personally I will accept up to 1ml if time predicts, but prefer to get to, or as close to, no fallout if time permits.
Offline RIngrey
Re: 27/3 test
« Reply #6 on: February 15, 2011, 06:30:34 PM »
Cheers guys for all the help and advice. :)
