Author Topic: New processor.  (Read 17323 times)
Re: New processor.
« Reply #45 on: April 08, 2013, 06:31:55 PM »
OK my 2 pence worth.
The venturi is on the wrong line, that T will kill the flow, it should be on the direct pipe and the eductor on the T'd off line.
The eductor feed should be as close to the tank return as is practical to reduce to a minimum any dead areas of wvo.
Offline Oilybloke
Re: New processor.
« Reply #46 on: April 08, 2013, 07:13:44 PM »
Thank you Jim. I thought that it was more important to have a straight & unhindered feed to the eductor, but it is simple enough to change. I don't quite understand what you mean by 'the eductor feed should be as close to the tank return'......
Re: New processor.
« Reply #47 on: April 08, 2013, 10:26:59 PM »
[/quote]
I'm assuming you have an eductor on the end of one of those pipes, if not then why do you have two feed lines?
Offline Oilybloke
Re: New processor.
« Reply #48 on: April 09, 2013, 06:38:07 AM »
[/quote]I will have Jim. Just waiting for any comments before committing to anything!
