Author Topic: New processor.  (Read 16259 times)
Re: New processor.
« Reply #15 on: April 07, 2013, 07:45:11 PM »
So which is better, tinypic or photobucket?  For the purpose of this exercise we want the one that is simplest to use.
I use my own webspace, so don't use either and welcome opinions before I go ahead.
Re: New processor.
« Reply #16 on: April 07, 2013, 07:53:20 PM »
Uploaded to tinypic ... seems really easy. The security question is a bit annoying, but here are the first two.  Pudding's ready (don't normally get a pudding), so I'll up load the others after pudding and take some screen grabs at the same time ...
Re: New processor.
« Reply #17 on: April 07, 2013, 08:08:14 PM »
imgshack.com
Re: New processor.
« Reply #18 on: April 07, 2013, 08:18:02 PM »
They will probably have signed up before they find they cant use it, just post the instructions up in a sticky, maybe RM can do one for imgshack?
Re: New processor.
« Reply #19 on: April 07, 2013, 08:25:57 PM »
The straight run from the pump to the reactor, what's on the end of it inside the reactor ?
I ask as the venturi should be on this run, not T'd off of it, as the T will reduce flow and have adverse effects of on the venturi.
A little tip is to pull the swept bends slowly, this stops the rippling on the inside of the bend.
What volume is the tank ?
Re: New processor.
« Reply #20 on: April 07, 2013, 08:26:05 PM »
venturi hieght is that ok there?
2 heaters isnt one abit high?
glyc take out can you get a bucket under tap/pipe?
site tube so you see level is over second heater and or float safety switch
« Last Edit: April 07, 2013, 08:28:14 PM by Confucius »
Re: New processor.
« Reply #21 on: April 07, 2013, 08:34:14 PM »
They will probably have signed up before they find they cant use it, ....
I didn't need to sign up for tinypic ... is that normal?
Re: New processor.
« Reply #22 on: April 07, 2013, 08:40:31 PM »
Re: New processor.
« Reply #23 on: April 07, 2013, 08:46:29 PM »
Haven't a clue, not even sure if you need to with PB, just assumed you would have to, i think they are all pretty much the same tho
Re: New processor.
« Reply #24 on: April 07, 2013, 08:50:39 PM »
 Final two ...
Re: New processor.
« Reply #25 on: April 07, 2013, 08:52:20 PM »
nice stack of oil ready for processiing, can see the need to get your system made now  8)
Re: New processor.
« Reply #26 on: April 07, 2013, 08:57:20 PM »
Just looked a bit closer, and I think you need to sign up to create albums etc.  So I'm guessing without logging in you can upload photos but have to remember their URLs.
Re: New processor.
« Reply #27 on: April 07, 2013, 08:58:33 PM »
So can I, it looks like this, £1.47.9  per liter.
Re: New processor.
« Reply #28 on: April 07, 2013, 09:01:13 PM »
lol - wash your mouth out with soap... garage forcourts are scary places...  :o
Re: New processor.
« Reply #29 on: April 07, 2013, 09:27:11 PM »
Julian, I need some soap.
