Author Topic: Can crushers and log splitters  (Read 16521 times)
Re: Can crushers and log splitters
« Reply #1 on: March 19, 2013, 10:48:31 PM »
Commendable thinking but if you scaled that up, you'd never reach high enough to load the drums.
« Reply #2 on: March 19, 2013, 11:07:13 PM »
What about this then?  I seriously want one :)
http://www.liveleak.com/view?i=111_1363524786
« Reply #3 on: March 19, 2013, 11:20:27 PM »
Don't fancy one of these for splitting logs then?  http://www.youtube.com/watch?v=vmtMv7Cz0HA
« Reply #4 on: March 19, 2013, 11:30:59 PM »
Those wood splitters are for girls and those that drink cocktails with brollies, this is my favourite! ;D
http://www.youtube.com/watch?v=La5hqhUaj_g
« Reply #5 on: March 19, 2013, 11:39:49 PM »
Ha, I spit at the feet of your screw-driven-log splitter!
http://www.youtube.com/watch?v=hhmKBDIAXd0
« Reply #6 on: March 19, 2013, 11:43:18 PM »
Been looking at those since before getting the log burner.  I can't work out how to turn the screw on my lathe without a taper turning attachment.
You can make a little one quite simply, by cutting the head off a large coach screw and sticking it in a cordless drill.  Works a treat, I use it for splitting old decking into kindling.
« Reply #7 on: March 19, 2013, 11:56:36 PM »
Why not use one of those cone bits for drilling holes in metal?
Although its nice there is absolutely no danger using that one and no self respecting red necked hillbilly will go near it! hahaha
« Reply #8 on: March 20, 2013, 12:12:09 AM »
It's not the cone that's the issue, that's quite easy.  It's putting a thread on it that's a problem.  I have seen a video of someone doing it freehand with an angle grinder but it was a bit of a mess!
« Reply #9 on: March 20, 2013, 12:30:37 AM »
« Reply #10 on: March 20, 2013, 12:33:54 AM »
http://www.liveleak.com/view?i=602_1363631381  8)
whoever said they could watch that all day has never worked on a production line. jars of jam, 7 lb tins of jam they were hot as well,  body panels for transits, pagers, daffodils. arrg its all coming back to me. will be dreaming about it now.
Offline hifly
    • waste oil devizes
« Reply #11 on: March 20, 2013, 04:49:38 AM »
if you turn the taper by offsetting the tail stock then you should be able to screw-cut it in the normal way
VW T4 2.5Tdi
« Reply #12 on: March 20, 2013, 08:13:21 AM »
I did think of that, but due to the angle involved, I don't think a standard dog would drive the work.
« Reply #13 on: March 20, 2013, 08:14:34 AM »
I think you all ought to think seriously about using coal
« Reply #14 on: March 20, 2013, 08:30:44 AM »
You can turn a tapered screw by offsetting the tail stock and working between centres and using the standard screw cutting system. To get a large taper angle make a pair of centres with ball ends rather than points. In the past I have centre drilled a centre and put a ball from a ball race between the workpiece and the centre.
If you want to buy a small one there are tapered threads used to hold polishing mops on polishing lathes.
http://www.ebay.co.uk/itm/Bench-Grinder-Spindle-Adapters-Polishing-Kit-SAPR-0012-/280794070270
Dick
