Biodiesel => Chemistry and process => Topic started by: thewormman on October 28, 2013, 11:20:59 AM
Title: Waxing - a possible cause and solution?
Post by: thewormman on October 28, 2013, 11:20:59 AM
After having a few problems with waxing as explained here
http://www.biopowered.co.uk/forum/index.php/topic,1585.0/topicseen.html
I have been looking into what maybe causing it and how to prevent it.
I had thought that putting Coldflow into my finished Bio would keep it usable down below 0 °C but was shocked when I had wax forming in the bio that blocked a J cloth within a litre or so being filtered when the temp dropped to 8 °C overnight and about 10 °C during the day, towards the end of September.
(http://i250.photobucket.com/albums/gg244/zukenstein/Bio/scum/Photo2_zpseb44de7b.jpg) (http://s250.photobucket.com/user/zukenstein/media/Bio/scum/Photo2_zpseb44de7b.jpg.html)
Since my wife and kids use the car without me, including trips down country lanes in the evenings I really had to get it sorted so it wouldn't break down on her. So it was off to the tax station again temporarily, focuses the solution finding mind  >:(
My Process:
Liquid oil, rapeseed/soya mix, usually no more than 5% solids, glyc washed, well dried 2 stage ASM non tit, after 2nd stage clear pass on the 10/90 drain 2nd stage glyc and demeth, acid wash with vinegar and 10L of water. Further washes till clear, final filter through a j cloth before a 1micron sock.
So information I had and clues I gathered:
Wax seemed to form when temp drops below 11 °C
Apparently according to Uncleh on VOD who gets the same wax build up, if he does not demeth but just washes he doesnt get it.
I believe Nigelb has stated he doesn't get this wax and he does a water prewash and doesn't recover methanol so methanol is still present.
My first batch that I made some mistakes with had a lot of methanol still in it when I washed it, I still had a jar sample of this and when I stuck it in the fridge at 5 °C there was no wax build up.
It has been mentioned that there are maybe 2 different types of wax/HMPEs that form, one at low temps (0 °C to minuses) and one at higher temps (the wax I had)
So I did some research to try to find something that could be:
Present in bio at below 11C but not when warmer.
Not washed out by just water washing.
Reduced by water washing with methanol present by not demething or by doing a water prewash.
I thought maybe the 'wax' must already be in there and was not being converted to Bio during the process so I looked at what was in the feedstock. Free Fatty acids are present depending on the source of the oil, amounts vary due to the source. These are not really converted very well with alkaline catalyst and what isn't converted usually combines with any water to form soap, hence the need for dry oil, a titration is used to measure the level of ffa's in your feedstock thus allowing you to add the correct weight of catalyst above the chosen base figure. FFA's are then turned into soap when the methoxide is introduced into the reactor.
Obviously soap is formed in the reaction and this is what is washed out once it is completed.
BUT...
When I looked at the types of FFAs typically found in the feedstock there was one that stood out,
Oleic Acid
From Wikipedia http://en.wikipedia.org/wiki/Oleic_acid
Appearance - Pale yellow or brownish yellow oily liquid with lard-like odor
Melting point - 13-14 °C
Solubility in water - Insoluble
Solubility in methanol - Soluble
It appears in the following amounts:
The majority of olive oil
20-85% of sunflower oil
37-56% of chicken and turkey fat
44-47% of lard
So in conclusion could some Oleic Acid pass through the bio processing as it:
Doesn't convert well using base catalyst just like all FFAs.
It doesn't turn to soap as it is not soluble in water.
It doesn't show up in the 10/90 test as it is soluble in methanol.
It turns to a yellowish lard/wax below 13 °C and this appears to be what I have?
This may explain why some get this and some don't, it depends on feedstock, amount of olive oil/sunflower oil present, what's cooked in it, etc, etc.  My thinking is that when methanol is present in the bio the Oleic acid is dissolved by it and it is then washed out in the water washes with the methanol. If the bio is demethed the Oleic acid is still contained within the bio as bigger molecules that are not soluble so are not washed out.
Non water washers probably see this at the bottom of their settling drums and it is generically called 'soap'.
I was told to filter oil as I needed it and keep a sample outside so I would know when the wax/HMPEs had formed, trouble with that is if there is a cold spell and the bio is in the car for a few days I'm screwed.
So to solve this I have got a cheap chest freezer for £25 and wired a PID and SSR on it. I've cooled 20 litres of bio down to 0 °C so the wax forms, filtered it through a pillow case to take out the worst of it then through my final filter of J cloth and 1 micron sock.
This is it at 0 °C. That is condensation on the jar the bio is clear.
(http://i250.photobucket.com/albums/gg244/zukenstein/Bio/scum/0_degrees_filtered_zpsc6b9b3c4.jpg) (http://s250.photobucket.com/user/zukenstein/media/Bio/scum/0_degrees_filtered_zpsc6b9b3c4.jpg.html)
I let it warm to ambient then cooled it again to 0 °C nothing in it still clear.
Even at -4 °C its getting cloudy but still liquid, I suppose this is the coldflow doing its job.
(http://i250.photobucket.com/albums/gg244/zukenstein/Bio/scum/-4_degrees_filtered_zps8065a9fa.jpg) (http://s250.photobucket.com/user/zukenstein/media/Bio/scum/-4_degrees_filtered_zps8065a9fa.jpg.html)
My finishing process from autumn through to spring now will include cooling the washed bio down to at least 3 °C below the average temp for the time of year before final filtering. This will hopefully mean I will not get caught by any cold snaps or need to fix the car at the side of the road, or rescue the wife.
Many will say don't bother or what I have described is rubbish as what they do completely contradicts what I have said, but when my family is going off in the car I want them to come back safe and I'm a worrier.
This seems to be working for me but others may not agree that is their prerogative.
All I know is if the car broke down she would NEVER let me hear the end of it so I will be doing what seems to work for my bio from now on....
Title: Re: Waxing - a possible cause and solution?
Post by: Head Womble on October 28, 2013, 10:54:48 PM
Very interesting Dave,
this may explain why two stage non titration in conjunction with WBD produces so much of what we know as HMPE.
If these critters dissolve in methanol then they wont get included in the calculations for the second stage,
this will also explain why we use less meths and catalyst with this method.
So maybe the old two stage titration method is the way to go.
Thinking about it, it also explains why I loose so much bio in the wash stage.
Post by: Chug on October 29, 2013, 09:51:06 AM
If you have a clear 3/27 then you shouldn't have any unconverted TG's.
Anything precipitating out will be methyl esters with higher melt points.
The only real way to make sure your fuel is gonna work at the temp it's used at is to chill and filter to the same or lower temp, as you say you are now doing, but if it goes much colder than the filtered temp you may find more appearing, it's all dependent on the type and amounts of the different fatty acids making up the feedstock.
Post by: Tony on October 29, 2013, 09:33:44 PM
From what I've seen I get more waxy fallouts from batches with incomplete conversion.  This kinda ties in with monoglycerides which would get washed out if present - and I thought the consensus was that water washing did help?   That or the wash water is always cold enough to cause earlier waxing - a bit like taking it down below ambient.
Did you read about reprocessing wax (or HMPE as we assumed it was at the time?)
http://www.biopowered.co.uk/forum/index.php/topic,889.0.html
Post by: Head Womble on October 29, 2013, 10:28:06 PM
Assuming we all use mains water I can't see how we can get below ambient at the time of year we need it.
Think about it, the mains water is generally a couple of °c off ground temperature.
Tony, today I've been thinking about your overdose method, if wormman is right, and my thoughts on two stage non titration have any founding, then your method should not suffer in the same way.
Post by: Julian on October 29, 2013, 10:45:58 PM
I've measured my mains water temperature on several occasions in winter and regardless of ambient it seem constant at around 9 -10°C.
Post by: Julian on October 29, 2013, 10:50:49 PM
Yes, all the tests I did were pretty conclusive that water washing drastically reduced (what we call) HMPEs ... possibly more so than any of the winterisers.
Post by: Head Womble on October 29, 2013, 10:52:12 PM
I've never measured it, but you've just backed up my thoughts.
Post by: Head Womble on October 29, 2013, 10:54:13 PM
Did these test include batches that had been demethed before washing and batches that weren't ?
Post by: Julian on October 30, 2013, 01:15:42 AM
Certainly my bio had been.  Not sure about Keith's and Niges, I suspect some of theirs hadn't from what I know of their processes.
Post by: whatarascal on October 30, 2013, 03:44:00 PM
If we let these waxes or whatever they are build up,what is the best way to filter "say"a 150 litre batch.
I will probably have to do some tests.
my process is sort of Dry 2 stage demeth.
The waxing will start  at some point near the end of my process," not yet this year i hasten to add"I demeth and don't pre-wash with water then bubble from demeth temp to  30c for 24hrs ,settle for some time.
Its after the heaters are switched off that the flakes start to appear when temps are close to zero or even higher.
I have tried coldflow additives after the 24 hr period and before last of soaps "or whatever"have dropped out.
This has caused a lot of stuff"dont know what "to precipitate out,and freezer tests on the bio have been less than if the coldflow was added after settling for a week.
This stuff sticks around the inside of the drum so it must be sticking to inside of pipes i suppose.
Anyhow if we get these waxes how the bloody ell can we filter them out without blocking filters
Post by: Tony on October 30, 2013, 04:30:34 PM
I pumped the liquid off the top, leaving the cream at the bottom.  This then gets reprocessed.
Overdose definitely helps but I still do get it when I'm processing some nasty oil and fail to add enough catalyst (3/27 dropout seen).
I still think there are likely several causes of waxing, but I'm pretty convinced monoglycerides are one of the major causes, because with my wax:
- it's soluble in Methanol but cloudy
- attempts to wash a sample creates hell of an emulsion that doesn't easily split
- if reprocessed it turns into liquid bio that doesn't form creams again
Post by: K.H on October 30, 2013, 08:49:54 PM
I dont demeth before washing, as the water removes the meth i consider it a wasted effort, my wash tank is outside so i assume the bio is pretty cold during winter  ;)
Post by: nigelb on October 30, 2013, 09:14:58 PM
I'm with Keith and echo his comments.
In my process with no HMPE or Oliec Acid issues I consider the demeth process redundant. A good water washing method has the ability to remove an awful lot of problems. Mind you feedstock, clearly, is a major here as well.
It still surprises me just how difficult some make it. 8)
Post by: whatarascal on October 30, 2013, 09:22:07 PM
Nige
I think it would be great if you put your process from start to finish on wiki or whatever then we could all benefit from your fountain of knowledge.
Post by: Tony on October 30, 2013, 09:22:33 PM
It still surprises me that some people are happy to just flush Methanol away, but there y'go. ;)
Post by: nigelb on October 30, 2013, 09:28:32 PM
I only flush/wash a little bit away. Just the stuff that remains in the raw bio.
The stuff that's left behind in the glyc migrates to the oil in the two glycerine washes I do. So no waste there.
 I think that the time and effort in getting another pump to circulate water in a condensor and putting together an efficient condensor and additional pipework would not be cost effective....for me.
Post by: 1958steveflying on October 30, 2013, 09:30:28 PM
I,m with Tony on that, I am also surprised that most of those that "wash the methanol out" do not accurately test for methanol afterwards.
Post by: K.H on October 30, 2013, 09:31:02 PM
Still surprises me people will spend hours in a shed to save a few pence, esp your shed  ;D
Post by: nigelb on October 30, 2013, 09:36:04 PM
I dare say that could be said about most processes ;)
Post by: whatarascal on October 30, 2013, 09:43:31 PM
I think all households should be water metered as water washing is wasteful ,no matter how convenient it is to some bio producers.
Post by: nigelb on October 30, 2013, 09:45:12 PM
Nige
I think my process is well documented both on here and the VOD.
Try using the search facilities on both sites to get hold of the info you so desperatly require.
 If  the searches fail let me know your email address and I'll send you a full flow chart of my process from start to finish.
Regards
Nige
Post by: nigelb on October 30, 2013, 09:47:14 PM
You're quite right Brian...it can be quite wasteful. I, however, use 40lts of harvested rain water to wash my fuel. No waste here ;)
Post by: K.H on October 30, 2013, 09:50:08 PM
AFAIK you only need to test the water a couple of times to know roughly how much water it takes until the meth has gone, normally long before the soap has.
Unless someone knows different? I'm not aware of anything that can vary the time the meth stays in the bio
So in my case if I get to soap free I can assume I'm meth free
Post by: whatarascal on October 30, 2013, 09:52:42 PM
Sorry mate harvested rainwater dont come into the equation.
That harvested rainwater should go into the ground to help feed us and the plants around us
Post by: Julian on October 30, 2013, 10:02:17 PM
While people water lawns and wash cars, I certainly won't care about washing my bio
While the water companies waste millions of litres each week through leaks, I too won't care about washing my bio with mains water.
Just imagine if our gas distribution system had the same level of leakage.  Do the water companies care ... of course not because they charge us for the water they leak!
Post by: whatarascal on October 30, 2013, 10:10:05 PM
Why care
cos someone has to
Post by: Head Womble on October 30, 2013, 10:11:27 PM
I went back to water washing some time ago, and no I don't recover the meths, I've even removed the squirrel.
I do still have my SHHE and quad core condenser but only use that for dewatering really wet oil before gly washing.
I offset the water used by not washing.
Since changing my process I haven't suffered from any waxing, I'm sure it's there but I just haven't suffered from it.
Post by: greasemonkey on October 30, 2013, 10:14:20 PM
I waxed my squirrel, then washed it with water. I don't know if it suffered or not. :o
Post by: K.H on October 30, 2013, 10:15:16 PM
Why care
cos someone has to
Fair comment
Post by: K.H on October 30, 2013, 10:17:39 PM
Easy to tell, if it's Red it probably suffered
Post by: Head Womble on October 30, 2013, 10:19:56 PM
If it's grey if suffered over many years.
Post by: whatarascal on October 30, 2013, 10:22:25 PM
 I don't water wash, to be honest its a lazy way of producing our fuel.
We need to find alternative energy efficient ways of producing our fuel and that is what our forums are about,aint it
Post by: whatarascal on October 30, 2013, 10:35:59 PM
Leaking into the the ground or via biodeisel processors is the same thing.we are all responsible,aint we?
Post by: Head Womble on October 30, 2013, 10:44:39 PM
I don't see water washing as a lazy way, demeth and settle is far easier, but after seeing the inside of my injection pump I'm conviced water washing is a better way to finish our fuel.
Post by: whatarascal on October 30, 2013, 10:53:41 PM
I don't think the thread is going off topic as i believe we need to find a more efficient way of producing our fuel.
O.ne way to do that is to get  together and let go of some of our hard and fast views about water washing
We don't need to water wash,it is a waste of resources,we need to find better and more efficient ways of  producing something ,that in the scheme of things costs us very little.
Try harder. like using koh,why? cos after a while it can be used as  a fertilizer.
Water washing is a waste no matter who the wastrel is
Post by: Julian on October 30, 2013, 10:58:52 PM
Perhaps then we should all stop making biodiesel, as running on veg is far greener.
Post by: Head Womble on October 30, 2013, 10:59:56 PM
We're already reducing the use of the planets resources,
yes I'm sure this can be reduced further,
however with differing feed stock we all need to find a method that works for us.
Post by: whatarascal on October 30, 2013, 11:01:55 PM
By lazy I didn't mean a physical thing, I meant a   challenging way of  producing our fuel,thinking about every step we take and saving all we can for the environment ,therefor for our children
Post by: 1958steveflying on October 31, 2013, 02:39:45 PM
Out of interest how many water washers use mains water and are on a water meter ?
Post by: K.H on October 31, 2013, 04:00:07 PM
Me :)
Post by: whatarascal on October 31, 2013, 04:10:54 PM
Me :)
good for you keith
Post by: Oilybloke on October 31, 2013, 04:28:21 PM
I have recently started water washing with mains water (no meter), but have just had a problem inasmuch as we are not on mains drains...........what does soapy water do to a soakaway?
Post by: 1958steveflying on October 31, 2013, 04:39:02 PM
      What catalyst do you use ?
Post by: Oilybloke on October 31, 2013, 04:40:25 PM
KOH.
Post by: 1958steveflying on October 31, 2013, 04:51:38 PM
KOH.
  Between NAoH and KoH I would have thought KoH to be the least harmful, but I would think it would depend on concentrations and volume alongside what is feeding from that soakaway. (you don't want everything within a 10 metre radius dying)
   Hopefully someone on here with have the knowledge to answer your question with some accuracy.
Post by: Julian on October 31, 2013, 08:22:23 PM
KOH.
Do you mean soakaway or septic tank?  Either way I can't see too much difference between sticking neat bleach in the loo and washing bio.
Have you thought of titrated acid washing?  If you get it right you wash water should pretty much be a neutral pH.
Post by: K.H on October 31, 2013, 08:49:50 PM
Too much in a septic tank would upset the balance I would think
Post by: willbuild on October 31, 2013, 08:54:38 PM
The amount of water in and on the earth has been the same for millions of years, it is either underground on the surface or in the air.
so you can't deplete the amount of water in and on the planet.
77% is salt water. what varies is how its distributed on the planet, so if you waste more you pay more if you are on a meter depending on where you are.
Post by: willbuild on October 31, 2013, 08:57:38 PM
bleach is a no no in a septic tank. the bacteria is what breaks down the sludge. so i would think that koh or caustic would have the same effect
Post by: Oilybloke on November 01, 2013, 07:09:09 PM
Deffo a soakaway.
Post by: slabster on November 04, 2013, 05:26:58 PM
Pure water is used in most commercial plants as part of the polishing process.
If water is a problem why not demeth first then settle then water wash when you get a clear 50/50 that way your fuel will super clean and you could reuse the water for another batch. Plus any waste wash water you do have to dump is not over polluted.
Slabs
Post by: slabster on November 04, 2013, 05:28:58 PM
You could nutralise the waste water with an acid probable sulphuic as a sulphate is less toxic than a cloride salt.
Slabs
Post by: slabster on November 04, 2013, 05:34:16 PM
The waste water can hold a bit of bio. I remember Golden Fuels ended up with about a 1000 litres of Bio in their waste water holding tank. The soapy water was all ways drawn off from  the bottom by tanker lorry.
I am sure there was discussion over on info pop (in the old days) about setting a small treatment system that could purify the wash water and reuse it in the process.
Slabs
Post by: K.H on November 04, 2013, 08:24:47 PM
Slabs
I agree, with a bit of thought the water can be reused, ie the last cleanish wash water can be used for the prewash and any water can go in a non overflowing tank to get the level up before mist washing
