Whole batch demeth
Starting the demething stage of WBD
Whole batch demeth (also known as WBD) is a method that requires you have a venturi and condensor as per the GL Processor design or other suitably safe equipment for recovering methanol from biodiesel.
First some notes
So with 100L wvo and 22% methanol (22 litres) there is 9.5 Litres excess methanol available for recovery before problems can occur. So we only take 9 litres then bubble off any residual methanol using air once the glycerol has been drained, or just continue demething the bio on it's own in your processor. If you still don't understand there is a guide to stoichiometric amounts and how much is recoverable here
Or the following chart can be used
Or even easier, as it's recoverable, why not just use 25% methanol to start with then it's just under half of what you started with available to be recovered.
The method
Start demething and try to keep the vapour temp, or head space, or still head, between 65°C and 70°C (for better methanol purity) and keep recovering until you have recovered most of the excess methanol, stop and allow glyc to settle for up to an hour (be aware that NaOH based glycerol will set hard quickly and cannot be left too long) drain the glycerol and move biodiesel to your settling tank, bubble with air for a few hours or overnight in a well ventilated space, allow 12-24 hrs for soap to dropout and then filter your bio using your preferred method and use or store.
Prewash
If you previously used a water prewash as part of your method you may find it's no longer necessary, but if you would still like to prewash then do it after demething the excess methanol, but BEFORE settling and draining off the glycerol, after prewashing settle and drain off glycerol and water, and move bio to your settling tank, bubble with air for a few hours or overnight in a well ventilated space, allow 12-24 hrs for soap to dropout and then filter your bio using your preferred method and use or store.
