Water in fuel - test kit
[hide]
Parts list
- 1/4" Y piece
- 1/4" Ball valve
- Bicycle "presta" valve
- 1/4" male stopend
- 43mm solvent weld joiner
- Small plastic cap/cup
- Small marble
- Viton O ring
Assembly instuctions
- Drill a hole in the stopend
- Weld one screw cap on
- Drop in the marble
Ingredients
The reagent
Dry solvent
The idea
The method
ASTM
The maximum PPM in vegetable oil is <400
The maximum PPM in biodiesel is <500 EN14214
Biodiesel will hold 1500 ppm of water before going cloudy.
Calibrating
Warning
Do not use on a liquid that is obviously wet, I have taken mine above 80psi and when it reaches its limit the gas escapes from the threaded cap BUT there is a danger it could explode at high pressures.
Hydrogen a highly explosive gas is made when using this kit.
