Waste oil filtering system
Homemade Filtration System
Parts List
- 22mm copper pipe
- 15mm copper pipe
- 22mm lever valves
- 15mm inline valves
- Copper joints various
- TAM105 electric pump
- Acrylic site tubes
- Filter housings + brackets
- 200 LTR steel barrels + Clamps
- Electrical cable + 3 pin plugs
- Immersion heater element + back nut flange
- Wooden frame base for housing rig
Processing
Clamp a cotton sheet over drum for first stage filtering in drum 1 (larger particles) this collects part fats and chips etc, when settled the part filtered oil can be drawn off from a pipe/valve slightly higher than the base (200mm), away from the water and fats settling area (Safe zone/Crud layer). This is now placed in drum 2 for heating upto 60°C (Drying), roughly takes about 3 hours to reach dependant on ambient room temperature. Once heated settle for at least 1 week, water and fats drop faster when heated and cooled/settled. After settling period pump oil through first set of filters into holding drum 3 or 4, oil is pumped through 50 and 20 micron stage filters, gradually reducing the micron at each stage, last set of filtering takes oil through 10 and 1 micron filters when pumped into your desired container for pouring into your vehicle.
Rotary-Motion 17:47, 4 December 2010 (UTC)
