Using acetone to aid soap removal
The use of acetone to aid soap removal in water washing was something that was first discussed by Nathan and Steve on this forum,
testing has been done by Mark.
First test.
The initial test was done with a 250ml sample. This had already been water washed and had a soap content of 76ppm. It showed a clear 50/50, 4 drops of acetone were added, the test was then shaken and left to settle.
It clearly shows more soap has been liberated into the water.
Method.
Turn pump off and let the water settle, this normally takes a few hours to obtain a good split of bio and water.
I see no adverse effects of adding acetone to the bio as it's quite a common practice to do this to aid combustion.
