Titrating with turmeric
PLEASE NOTE
Turmeric has a very strong yellow colouring and can seriously stain materials it comes into contact with.
Why we use indicators to titrate
When titrating WVO to make biodiesel, we use an indicator solution to tell us when the FFAs have been neutralised. Experience has shown that pH meters don't work with wvo and are no substitute for a simple titration using indicator solution.
All about indicators
Indicators are substances that change colour at a certain pH. All indicator solutions are made by adding a little bit of an indicator to a lot of alcohol. They do not change colour until the solution they are in becomes acidic or alkaline. The three most common indicators used for making biodiesel are phenolphthalein, phenol red, and turmeric. Phenolphthalein and turmeric change colour at the correct pH but phenol red does not.
What is a "blank titration" and why do I care?
The alcohol used to make indicator solutions may itself be acidic. This may also be true of the isopropyl alcohol used as a solvent in the titration itself. So it is common practice to do a "Blank Titration" to neutralise any acid which might be in the alcohol itself.
Turmeric indicator solution starts to change colour between pH 7.4 (above neutral) and pH 8.5 (alkaline). For our purposes as biodiesel homebrewers, this is accurate enough. With some alcohol, adding just one or two drops of NaOH/KOH tester solution to a "Blank Titration" may achieve a colour change but with other alcohol it may take seven or eight drops.
What does it mean to "neutralise" free fatty acids (FFAs) to pH 8.5
So if one person's turmeric indicator starts yellow and changes into an orange-rose and someone else's starts greenish-yellow and changes into orange or red (as in this example picture at the bottom of the page), it doesn't matter. What matters is that the colour has changed from the original yellow colour to the same colour as your blank titration and stayed that way for 30 seconds, do some tests with your turmeric and observe the shade or colour it actually changes to when blanked.
This means that you shouldn't "push" a turmeric or phenolphthalein titration to yield a particular shade or intensity of colour. As soon as the color changes and persists for 30 seconds, the titration is complete. The key is to use a consistent approach from titration to titration, it should be noted that when titrating with turmeric the titration mixture has a cloudy look to it and is not clear like phenolpthalien.
Preparation
Reference solution
  1. Thoroughly mix ground Turmeric with Isopropyl Alcohol using 1 part turmeric to 5 parts alcohol
  2. Let the mixture settle
  3. Decant the liquid into a small bottle with a dropper.
See sample A.
Blanking the isopropyl alcohol
  1. Measure 10 ml isopropyl alcohol into your titration vessel.
  2. Add several drops of turmeric indicator solution until the alcohol turns yellow. See sample B.
  3. Add just enough drops of NaOH/KOH tester solution until you see a 30 second red colour change. See sample C.
Titrating the waste vegetable oil
  1. Add 1 ml WVO to the 10 ml of Isopropyl Alcohol that you have neutralised in a "Blank Titration" as above.
  2. Mix thoroughly (it will turn yellow).
  3. Add drop by drop the NaOH/KOH tester solution until you see a 30 second colour change. See sample D, noting duller red colour than previous 30 second colour change due to the presence of WVO.
  4. Record the amount of NaOH/KOH tester solution you used
  5. Repeat Steps 1 through 4 until you repeat your results two more times
Turmeric titration colour changes
  • A = The prepared turmeric indicator solution ready for use
  • B = A few drops of Sample A + 10ml of Isopropyl Alcohol, ready to do a blank titration
  • C = Sample B + drops of NaOH/KOH tester solution added to get to required pH switch point or blank titration
  • D = Sample C + 1ml WVO + X drops of NaOH/KOH tester solution, note the dulling of the red colour due to the WVO.
