Pump - buyers guide
TAM 105 centrifugal pump
Flow rate
However, larger pumps require larger bore pipework, which is more expensive and often harder to fit. They also consume more power - so there is always a trade off.
At the minimum a pump should be chosen to turn over the batch volume in a few minutes. Typically a TAM105 at 40lpm can turn over a 160l batch (192l with methanol) every four and a half minutes.
Closed or open impeller
Multistage pumps
Materials
Most common water pumps come fitted with Noryle/PPO/technopolymer impellers, which are often a blend of polyphenylene oxide and polystyrene. These impellers are suitable for cold oil transfer, but not up the job of mixing oil with alkali catalyst and methanol in the presence of heat, as can be seen in the gallery below.
Look for a pump which has brass or stainless steel impellers.
Jet pumps
Jet pumps provide a built in ejector/venturi mechanism and are great at providing a lot of suction. However, they are invariably constructed of technopolymers, which makes them unsuitable for biodiesel equipment. In addition, if used for cold oil transfer, the greater viscosity of the oil is likely to eventually shear off the ejector mechanism in the pump.
Technopolymer pump gallery pictures courtesy of Mark aka Head Womble
