Plumbing fittings
A brief discription of the fittings and tools used in making a processor or filter set up.
Pipe
Fittings
Elbow/90/Street elbow
Coupler/Straight connector
A coupling connects two pipes to each other. If the size of the pipe is not the same, the fitting may be called a reducing coupling or reducer.
Reducer
A reducer allows for a change in pipe size.
Tee
A tee is used to either join or split a flow. Most are tees with the same inlet and outlet sizes, but reducing/unequal tees are available as well.
Tank connector
Valves
Ball valves/lever valve
Gate valve
Other
Dispensing nozzle
Check that the O rings/seals are biodiesel compatable.
Filter housing
Normally either 3/4" or 1" BSP threads.
If you use PTFE tape when fitting an immersion heater try and get the gas type as it is thicker.
Tools
Using a pipe bender.
Hold the pipe against the radiused former, then insert the straight former to support the pipe then pull the levers together.
Various
Hole size required.
Mechanical flange 65mm.
22mm Tank connector 1 1/16".
15mm Tank connector 22mm.
You can file or drill out the "stop" on tank connectors which will allow the pipe to pass through.
Most pumps i.e. TAM105s have a 1" BSP parellel thread so normally you would need 2 of 22mm compression x 1" BSP for your processor.
2 1/4" mild steel weldable sockets are available from a vegetableoildiesel forum member and a stainless steel version is obtainable commercially.
For a water washing spray nozzle the brass fitting on a cheap pump up sprayer is ideal.
Pockets
You can make a pocket for a thermometer or thermocouple by filing out the stop on a 15mm tank connector, pass a short piece of 15mm pipe through this and solder on a 15-10mm or 15-8mm reducer then solder in the required length of 8 or 10mm pipe and solder on an end cap.
Courtesy of JIM.M
