Mitsubishi Delica fuel system
Fuel system introduction
The Delica's 4M40 engine is equipped with a licensed copy of the Bosch VE pump, built by Zexel. This is gear driven from the crankshaft. It directly sucks fuel up from the tank through the fuel filter.
Inside the fuel tank there is a coarse strainer.
Because of the tough Zexel pump and indirect injection, this vehicle is suited to running on both biodiesel and vegetable oil.
Pipework
- 8mm ID on the tank lift, filter and pump inlet side
- 6.25mm ID on the pump's return spigot
- 5mm ID for injector leak-off pipe
Tank strainer
The strainer in the tank can easily block with wax or soaps if soapy biodiesel is run through the system. Because the in-tank strainer has a hole in the top, this blockage isn't usually noticed until the tank is down to 1/8th full, when the vehicle will stall.
The blocked strainer:
Fuel filter
Fuel pump
Input shaft seal
A known problem with these vehicles is failure of the input shaft seal. It sits in a ring around the input shaft (removed in this photo):
Symptoms include stalling 100m down the road after starting, oil in the fuel (black filters) and fuel in the oil (rising sump oil level due to oil dilution).
Replacement
Note that the camshaft has a flat and notch on top, visible through the oil filler cap, to indicate #1 piston TDC (though the accuracy of this depends on chain stretch). The pump also has a notched tooth that must remain aligned with a "T" (turbo) mark on the pump case - as opposed to the "N" (normally aspirated) mark. The crank should always be turned clockwise (turning camshaft anticlockwise) to avoid over-tensioning the chain.
Overflow restriction valve
Pump internal fuel pressure (and therefore injection advance timing) is influenced by a "pulling electromagnet" (Zexel name for the green capped solenoid at the back of pump). It sits above the stop solenoid on the rear of the pump.
The internal mesh can block up with crud and affect the pump's timing (injection is too advanced). It is also possible that the o-ring may no longer seal.
When parked there is no power to this solenoid so all ports are open. Without the one-way valve built into the Delica's filter head, this would let air from the return line into the feed line, which would drain back to the tank. If you suspect you have air in the pipe to the pump when cold started, make sure the filter head/primer arrangement isn't allowing fuel to flow backwards through it (take it off and try blowing through it the wrong way).
You might think it would be impossible to start with nothing but air in the pickup pipe, but it will start and idle (badly) on just the fuel left in the pump and filter, until some more makes it's way up from the tank.
Cleaning
Replacement
Note that it does not come supplied with an o-ring, which must be sourced separately.
However, there are notable differences. The original says "76" on the side and has two drilled ports on the loop side (three total). The new part above has "58" on the side and four drilled ports on the loop side (five total). This might suggest that the internal pump pressure will be reduced with resulting retarding of the injection timing, but in practise this seems to have no observable effect.
Cold start spring
The pump also has cold start mechanism on the side. This gives extra throttle at idle by pulling on the throttle lever, and advances the injection timing at low engine RPM by rotating a shaft into the side of the pump.
The coiled spring presses against a wax stat in the coolant system. When cold the mechanism turns clockwise (advanced injection & higher idle). When warm the mechanism turns anticlockwise (normal pump hydraulic timing & normal idle).
The top adjuster has an 8mm locknut and adjusts both cold throttle and advance simultaneously. The bottom adjuster has a 10mm locknut and just adjusts the cold throttle.
