Members vehicles running biodiesel or vegetable oil
Make Model Year Member's name Fuel Mileage on bio/veg Known problems Cures/Modifications and Notes
Mitsubishi Delica 2.8TDI 1994 Tony B100 50,000 miles / 5 years Blocked in-tank filter; increased cold start clatter with time; air leak at filter housing; dissolved pipework. Added facet pump to assist with lifting fuel from tank, when the IP shaft seal failed the sump filled with bio and engine ran away. Remove in-tank filter, replace with inline filter in engine bay; recon/replace injection pump; different filter housing fitted; all pipework replaced with Nylon air hose or marine graded diesel hose. Gave up on the Delica after the engine runaway.
Nissan Serena 2.0TD 1994 Tony B100 Few thousand None, sold fully working
Nissan Largo 2.0ETi 1996 Tony B100 20k between two Largos None, both run very smoothly on it
Peugeot 405 Estate 1993 PeteP900 VEG 40000 Not a lot RM Filter Mod
Peugeot 106 1996 PeteP900 VEG 5000 Not a lot RM Filter Mod
Citroen ZX 1994 PeteP900 VEG 12000 Not a lot RM Filter Mod
Citroen Xantia 1998 PeteP900 VEG 9000 Not a lot RM Filter Mod
Jeep XJ Cherokee 1996 PeteP900 VEG 35000 Not a lot LandRover Filter Mod (Purely cost of filters)
Mitsubishi Shogun / Pajero 1995 PeteP900 VEG 2000 Overheated, have to be Tesco's Oils fault None
Isuzu Trooper / Bighorn 1995 PeteP900 VEG 4000 + Not a lot FPHE
Leyland 7.5 Ton RoadRunner Motorhome 1989 PeteP900 BIO / Diesel 7000 Not a lot Secondary Inline Filter
Toyota Hi-Ace Regius 1996 TheRecklessEngineer B100 5000 miles None so far
VW Golf TDI 1.9 PD 2003 Julian B100 15,000 approx None After checking fuel temperatures (see this thread), happy to run bio all year.
Quote from VW hand book section 3.2, Art.-Nr.: 231.551.GOR.20 dated 05.2002 ... "RME fuel (diester) corresponding to DIN51 606. Vehicles with diesel engines can also run on RME fuel (Rapeseed Methyl Ester). Please use only RME fuel when filling up with diester."
VW Passat 2.0TDi 130 (PD) 2003 tttonyyy B100 + splash of 2-EHN Just a few k so far Fuel filter blocked after two or three tanks, felt like it was kangarooing up the road under heavy acceleration. Filter very easily changed and is right next to the engine (lovely warm location to help with winter waxing). In the winter requires a bit of extra glow or cranking to get started but nothing to warrant any effort. Otherwise, goes like absolute stink on the bio, really flies!
Vauxhall Astra 1.9 cdti 2006 rbdazza B100 10000 Turbo blew and fuel in oil from DPF. Other than that runs fine. Replace turbo and remove DPF and see how things go :)
BMW 530d M Sport 2006 rbdazza B100 10000 Getting fuel in the oil, not the DPF, could be a leaky injector, don't think its the bio! no mods, need to work out root cause of fuel in oil and get it fixed!
Mitsubishi Challenger 2.8TD 1996 Twenty4Seven B100 12,000 Fuel pump front seal. Replaced front seal with Viton. No issues since.
