Melting stick
Completed Melting stick. Source K.H
This is a useful, easily made item used to melt solid oil, palm oil, glycerine and whites.
Overview
Quote source: K.H
Components
Components used. Source K.H
Electrical connections. Source K.H
  1. ... 1 off ... cartridge heater 15mm outside diamater, 300W (available in various wattages)
  2. ... 1 off ... short length of 15mm copper pipe
  3. ... 2ft ... 15mm plastic pipe
  4. ... 2 off ... 15mm - 15mm straight compression fitting
  5. ... 1 off ... plastic pipe insert
  6. ... 1 off ... Stand-off (piece of metal slightly longer than the heater with the end bent over)
  7. ... 1 off ... cable and plug
  8. ... 1 off ... in line power switch
  9. ... 2 off ... insulated crimp connectors
  10. ... 2 off ... shrink sleeving
  11. ... 1 off ... Gp7 brass cable gland
Assembly
Connect the heater cable tails to the power cable by soldering and insulating with the heat-shrink, ensuring that the sleeve is securely attached and cannot slide away from the joint. Alternatively crimp connectors can be employed and, for additional safety, can be covered with heat-shrink sleeveing. Cutting one heater cable tail slightly shorter than the other, will ensure the joints are staggered making it easer to insert the cabling into the tube.
Tighten the heater into a straight 15 mm compression fitting using the nut with the stand off attached, then attach the copper 15 mm copper pipe to the other end of the fitting, feeding the cable through the pipe as it's assembled. The copper pipe needs to be long enough to prevent the plastic pipe from becoming too hot.
Attach the second 15 mm compression fitting to the other end of the copper pipe, by carefully threading onto the cable. Feed the cable through the pipe insert and the plastic pipe, and tighten the second compression fitting.
Disassemble the cable gland and slide over the cable. The pipe ID is the correct tapping size for the gland thread. If a chamfer is put on the inside of the pipe, it should be possible to screw the gland into position, the metal forming a thread as it's screwed in (warming the pipe may assit in this procedure). Take care not to wind up the cable as you install the gland body, or fit the gland before threading onto the cable.
Assemble the rest of the gland, ensuring that the cable is slack within the pipe and gripped satisfactorily so it anchors the cable if pulled.
A suitably rated inline switch fitted to the cable makes for easier operation.
Melting stick in action. Source: K.H
