Making bar soap from glycerol
A quick guide to making bar soap from glycerol.
Recipes courtesy of Chug.
Ingredients
  • 1 litre of demethed glycerol
  • Approx 80 ml of water
  • Approx 35 g of NaOH
You may have to play with these figures slightly to suit your glycerol, so test batches are recommended!
Method
Scooping out set glycerol. Source: K.H
Glycerol is heated with caustic. Source: K.H
Hot, liquid soap poured into mould to set. Source: K.H
After seven days, soap is turned out and cut to size. Source: K.H
  • Heat the water to 50°C and add the NaOH.
  • Stir until dissolved (do not breathe the fumes).
  • Add this mix to the glycerol and continue heating while stirring.
  • The mix will foam and froth then will start to thicken (now is the time to add any scents).
  • Allow the mix to cool slightly.
  • Pour the mix into your chosen mould and leave for 7 days to harden enough to be cut into squares. The soap will continue to harden over the next few weeks.
You can add essential oils such as lavender to the mix to give a nice fragrance and you can also add chopped herbs to impart a scent.
Adding silver sand, oatbran, bulger wheat etc to the mix makes a great exfoliating soap but you have to time the adding of it to perfection or it will sink to the bottom.
Moulds
For moulds you can use anything that will take a small amount of heat such as margarine tubs and recycling box lids. If you don't think you will get caught, muffin trays with the individual compartments are ideal!
Colouring and pH values
This soap will be an uninspiring muddy brown colour, but you can use small amounts of food colouring to alter it slightly. Don't overdo it or you will end up with a soap that stains your hands.
Chug also uses the soaps from his settling tank to give a lighter coloured soap than that made from glycerol.
Liquid soap
To make a liquid soap use KOH instead of NaOH. However, you must use the same catalyst that you used to make the glycerol.
This is a recipe for liquid soap made with KOH:
  • 250ml water
  • 40g KOH
Add any essential oils before adding the water/KOH to the glycerol. For less viscous liquid soap, add more than 250ml of water.
Warning
