Glycerine logs
Glog made from a carpet core and hard wood shavings from a window factory after 30 minutes burning.
Glycerine logs, 'glyc logs' or 'glogs' are fuel logs made of biodiesel waste and a suitable flammable absorbent material which can be burnt on a solid fuel appliance to produce heat.
Mixing the products
Glycerol
Absorbent
Mixing
It is important that the glycerine and absorbent are mixed thoroughly and left long enough for the glycerine to soak in.
Once mixed the mixture needs to be compacted into some form of container. Even if made from previously completely solid glycerine, the mixture will not set completely solid again. This means that excess can be stored in sealed containers if not all used at the time of mixing.
Moulding the logs
This is the simplest wasy to make logs. Anything of a suitable size for the intended appliance and made of a flammable material is useable. This makes old carboard containers (catfood pouch boxes, parts boxes etc). Tetra Paks cut open at one end and Pringles tubes are ideal.
Non-flammable moulds
Compacting the mixture
Burning the logs
Whilst there is no doubt that acrolein is produced from heated glycerol, the gas itself is flammable and therefore, in a flaming fire, will be ignited and broken down into simpler gasses.
The greatest risk of acrolein, and other toxic and unpleasant gasses, is with a smouldering fire. As such, glycerine logs should be burned with sufficient air to maintain a fire with visible flames. It is recommended that the fire is started with wood or other flammable material to ensure that sufficient heat exists to assist with the combustion of the logs.
The two pictures in this section show the same glycerine log on a wood stove. The left hand picture shown 10 minutes are placing the log on the fire, the right hand is the same log 30 minutes are being placed on the fire.
What is left after burning
Storing the logs
