Cone bottoms for tanks
Cone calculator. Source: Tony. Click graphic to access.
Cone bottomed tanks facilitate accurate splitting of oil and water, oil and glycerol (if you glycerol wash) or glycerol and biodiesel.
The easiest way to generate the shape or development for a conical bottom is to use the calculator complied by Tony. For security reasons this has to be located outside of the wiki, but it can be accessed via this link or by clicking on the grahpic, right …
Biopowered cone calculator.
Fabricated cone bottom. Source: JamesRL.
