3D Printed parts and spares
3D printed TAM 105 terminal box
TAM 120 terminal box
Fixing pillars within the box have been made considerably stronger by blending them into the box walls. Longer screws may be required as the wall thickness has been increased from the original design.
Leo XKM60 terminal box
Mono MS coupling covers
Often missing from second-hand pumps, this version is 2mm thick compared to the originals which are 1.5mm. Due to its shape quite a lot of plastic is used for support. Two are required per pump. Unfortunately this cover won't fit the MS predecessor, the M25, which looks similar and was never designed to have a cover.
20 ltr plastic can adapter
A threaded adapter which should fit most 20 ltr plastic cans and allows a 25mm ID PVC pipe to be fixed as a spout. This arrangement is useful for filling vehicle tanks without the aid of a funnel. A vent hole needs to be drilled in the top of the can to admit air. 25mm PVC pipe is available from most aquatic suppliers
A file is included to print the sealing ring using a flexible filament such as Ninja-flex. Alternatively a seal can be cut from a suitable material circa 3-4mm thick with the dimensions ... OD 62mm ID 50mm.
Due to the profile of the threads, the item is best printed at 100% fill, hose tail up and with support. Careful cleaning of the support remnants will be required.
Lowara CEAM 70/5-V terminal box
As with many other pumps the terminal box on this Lowara pump doesn't seem to be made to last. The replacement was designed with considerably thicker walls and sturdy reinforcement. Additionally, the capacitor housing was enlarged to make fitting after market capacitors easier.
Julian (talk) 12:05, 25 February 2015 (UTC)
