Author Topic: Water test  (Read 2409 times)
Water test
« on: February 09, 2013, 09:50:10 PM »
May be a whacky idea and I'm guessing that it wont be sensitive enough, but has anyone got a moisture meter, the kind with which you test walls and timber?
Might be worth a play.
Re: Water test
« Reply #1 on: February 09, 2013, 10:58:30 PM »
If you mean water in oil, I'd guess no as they are not ionic.
Bit like measuring pH of oil doesn't work, no H+ ions.
It's cod-science night over on the VOD BTW!
Re: Water test
« Reply #2 on: February 09, 2013, 11:21:42 PM »
the calcium carbide method works. i have a tin if you want to experiment. i brought 2 for about £20 and haven't used them. one should last me years. i can let you have one if you like. beers tokens to tony to help run the site as long as you pay the postage.
Re: Water test
« Reply #3 on: February 09, 2013, 11:40:32 PM »
Ah, that's a bit awkward!  I already said I'd pay next years costs!
Thanks, but it was just an idle thought ... a wacky, idle thought as it turns out.
