Author Topic: Vw oil cooler/fuel filter mod question  (Read 3666 times)
Offline Rossey
« on: February 03, 2013, 09:38:13 AM »
I remember seeing that someone (think rm)
Had a heated filter head from a vw oil cooler.
Does anyone know what size the connections are?
Re: Vw oil cooler/fuel filter mod question
« Reply #1 on: February 03, 2013, 10:15:08 AM »
water pipe connections?
cant remeber where mind came from wasnt it a pug oil cooler?
« Last Edit: February 03, 2013, 10:25:03 AM by Funky Kingston »
Offline Rossey
« Reply #2 on: February 03, 2013, 10:29:04 AM »
I found it there 16mm
The connections on my H/E are 12mm so I should run it in parallel rather than series?
Series would be a lot easier.
« Reply #3 on: February 03, 2013, 10:32:04 AM »
maybe heat ex before filter a FPHE. like on me van
i remeber k.h did the threading for me he had the tap
« Last Edit: February 03, 2013, 10:36:07 AM by Funky Kingston »
« Reply #4 on: February 03, 2013, 01:06:44 PM »
That is definitely a pug oil cooler. Maybe also find on a citroen, and possibly a renault.
« Reply #5 on: February 03, 2013, 02:27:58 PM »
Core dimensions 92mm x 92mm x 54mm
Mounting hole 20mm
Filter mating surface 66mm
Coolant hose tails 16mm
http://www.biotuning.co.uk/ShopFilters.htm
The bit that's essential for the VAG unit is the extension bar that runs down the center of the unit -
