Author Topic: Importance of venting a processer page  (Read 11727 times)
« on: February 01, 2013, 10:43:37 PM »
This is what I have so far.
http://www.biopowered.co.uk/wiki/Importance_of_venting_a_processer
Can someone spell check it for me please.
I'm struggling with the last section (positive pressure),
I don't want to get into exploding reactors as that's probably covered elsewhere and a vent will not stop this anyway.
Any ideas as to what else can be added.
Re: Importance of venting a processer page
« Reply #1 on: February 02, 2013, 01:12:28 AM »
looks good to me ,well done mark.
i will have to text over the art of esterification and get you to do a page on that.
paul
« Reply #2 on: February 02, 2013, 07:58:59 AM »
the main processor pic is abit dogged ie: lines through it all over ?
« Reply #3 on: February 02, 2013, 08:54:22 AM »
You really need the spell the title correctly - it should be a processOr not processEr. As an editor I don't think that you can do this though. As such you will need a Wiki Admin (julian or tony for instance) to change it for you.
I have also corrected 8 or 9 spelling mistakes where I found them, flexAble to flexIble being the main culprit.
Don't take it as a criticism, it is great that you have joined the editing crew and the page is looking good so far.
« Last Edit: February 02, 2013, 09:09:32 AM by julesandtash »
« Reply #4 on: February 02, 2013, 09:53:09 AM »
« Reply #5 on: February 02, 2013, 11:03:09 AM »
Hands up, the title was my mistake when I started the page for him.
« Reply #6 on: February 02, 2013, 11:05:33 AM »
Hmm, it might have screwed up when I exported it to png ... I'll have another go when I have time.  If in the mean time it's downsized a bit the lines won't be as obvious.
« Reply #7 on: February 02, 2013, 12:01:21 PM »
Lookin' good.  I've moved it to http://www.biopowered.co.uk/wiki/Importance_of_venting_a_processor
Is there a difference between moving and renaming?  Can't quite remember what I did, but last page I renamed didn't have the little "(Redirected from ..." text under the title.
« Reply #8 on: February 02, 2013, 12:03:25 PM »
Mark, I'll PM you with some suggestions tonight or tomorrow.
« Reply #9 on: February 02, 2013, 01:43:56 PM »
Thanks guys.
I'm lost without a spell check, believe it or not I think I did quite well, for me anyway.
« Reply #10 on: February 02, 2013, 04:01:42 PM »
I don't think so.  You only see the "redirected from" if you visit the old page (spelt -er).  If you visit the new page (-or) this doesn't appear.
Of course, the redirect is optional - in which case it'll ask you if you want to make a new page if you visit the old spelling (because it won't exist anymore).
« Reply #11 on: February 02, 2013, 04:19:16 PM »
You did!, good work
« Reply #12 on: February 02, 2013, 05:14:49 PM »
Ah, I see thanks Tony ... wondered why there was a difference.
« Reply #13 on: February 02, 2013, 07:16:48 PM »
Was that a clip top drum that imploded? I'm amazed it built up that much of a vacuum, without sucking air through the top. I suppose maybe once it had started to vacuum, then it helped hold the lid on. Still, I'd have expected the drum rim or lid to distort a little, before it squashed it like that.
Nice page by the way.
« Reply #14 on: February 02, 2013, 09:24:58 PM »
When I made my now infamous soap batches,
I pumped 200L of hot (60°) mayo into an empty 205 clip top and put the lid on to stop meth fumes from escaping.
As it cooled it sucked the lid down and distorted the drum, I couldn't get the lid off even when leavering it with a crowbar,
I then put a small hole in the lid with a 6" nail and the lid lifted off with ease.
So yes the lids do seal very well, even bettor with a small amount of negative pressure.
