Welcome,
Guest
. Please
login
or
register
November 26, 2025, 05:39:32 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
General
Chatter
mono pump
« previous
next »
Print
Pages: [
1
Author
Topic: mono pump (Read 1960 times)
william crosby
Wiki Editor
Oil stirrer
mono pump
on:
December 16, 2012, 04:47:31 PM »
knowing nothing about these pumps and how good/bad they are.Will they pump cold engine oil and how are they rated for flow.
thanks william
Logged
julianf
Wiki Editor
Grand Gunge Master
Re: mono pump
Reply #1 on:
December 16, 2012, 04:52:27 PM »
They will pump cold engine oil fine.
Flow will depend on the model. Some are way larger than others.
Mono is just the brand name - if you want a term to google, it's "progressive cavity"
Logged
For custom cnc cut instrument panels, see -
http://www.thebeast.co.uk
Collections website -
http://www.devon-used-cooking-oil-collection.co.uk
william crosby
Wiki Editor
Oil stirrer
Re: mono pump
Reply #2 on:
December 16, 2012, 04:54:08 PM »
thanks julian i need to look for one now thats probably the hard part
thanks william
Logged
Julian
Administrator
Oil baron
Re: mono pump
Reply #3 on:
December 16, 2012, 04:54:16 PM »
They are not high flow pumps, but they are excellent at pumping sludge and thick liquids. Self priming with a very good suction lift. They don't macerate the liquid, rather take gulps and push them through the pump.
One golden rule is NEVER run them dry or against a CLOSED suction or discharge valve.
Info here on the wiki ...
http://www.biopowered.co.uk/w/images/7/7a/Mono_MS_manual.pdf
http://www.biopowered.co.uk/w/images/d/d9/Mono_MM_and_ML_Manual.pdf
Not cheap to buy but well worth the money. Spares including Viton stators are readily available from Mono in Manchester.
Logged
Used Cooking Oil Collection website ...
http://www.surreyusedcookingoilcollection.palmergroup.co.uk
Print
Pages: [
1
« previous
next »
General
Chatter
mono pump
