Author Topic: USED EX BT D5W 12V EBERSPACHER WATER HEATER  (Read 10329 times)
Re: USED EX BT D5W 12V EBERSPACHER WATER HEATER
« Reply #1 on: November 24, 2012, 11:19:54 AM »
Nice find!  Like the avatar, I hope you're planning on passing that around ;)
« Reply #2 on: November 24, 2012, 11:25:13 AM »
Don't they only run on dino.
« Reply #3 on: November 24, 2012, 05:17:43 PM »
Eberspacher sell a Bio proof pump, then they are fine.
« Reply #4 on: November 24, 2012, 06:04:25 PM »
i like to share  8)
« Reply #5 on: November 24, 2012, 06:20:10 PM »
I have a D2 air heater (also ex-bt van!)
It really does not like bio.  Unstable, smokey burn.  Really not worth using on it.
Ive never burnt dino on it, but its flawless on kerosene.  Nice stable clean burn.
The D4 unit is specified to run on bio, but the D2 isnt.  The design is basically the same, so im unsure why this is, but all i know is that, for sure, the D2 is no good on bio.
Steve - which unit have you had sucess with?  I have been tempted to sell my D2 and get a D4, but i did not want to bother unless i knew with certainty that it would be ok.
Its not that kerosene is expensive for the amount it uses, its just the inconvenience of having two tanks etc.
« Reply #6 on: November 24, 2012, 07:05:39 PM »
On the net, somewhere, there is a site that delves into the reasons why the D4 unit will run on bio ans the D2 wont. It is something to do with the area of the burn chanber, and the way the fuel is ignited. I stumbled across it once, but have no idea where to find it.
Another thing to think about when buying second hand erberspachers, is that they can get lockout, where if its been started so many times, without actually working, a safety feature cuts in, and they need to be reset by the manufacturer. I dunno is that info correct or not, just another thing I remember reading somewhere.
I'd love to have one fitted, I'd just run it on Dino from a fitted tank. there are so many vehicles they were fitted to, emergency serevice vehicles, utilitys vehicles. There must be loads in scrap yards, and most people wouldn't know what they are looking at.
And it needs the control panel, it doesnt look like its with that one.
« Last Edit: November 24, 2012, 07:08:11 PM by greasemonkey »
« Reply #7 on: November 24, 2012, 07:34:27 PM »
Ive got a BN4 petrol heater for sale :)
« Reply #8 on: November 24, 2012, 07:57:18 PM »
Thats a scary looking piece of kit. i just googled it.
How does it plumb into the water jacket? Seems it heats the water through a heat exchanger.
Does it blast hot air out the back, or only down the exhaust pipe?
How much would one be wanting for it............?
« Reply #9 on: November 24, 2012, 08:58:42 PM »
Its just a vehicle heater,ive got two,one will be used in my camper,its like this one
http://www.ebay.co.uk/itm/Eberspacher-BN4-heater-for-VW-camper-crewcab-splitty-westfalia-/261122875386?pt=UK_Campervan_Caravan_Accessories&hash=item3ccc22dffa&nma=true&si=Hri0%2BtlIBvGysJn3s7mhasfgbNo%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
They have different air hoses one round one oblong,when i decide which outlet i will use i will sell the other.
The first one i had refurbished,the second i paid £100 for untested,i would be looking for my money back but i would want to make sure it works before selling
« Reply #10 on: November 24, 2012, 09:13:29 PM »
Ahhh, I thought it heated the water jacket. Great thing in a camper though.
Having starting problems now. Must get my act together.
« Reply #11 on: November 24, 2012, 11:41:21 PM »
I ran my D2 for a season on Bio without issue's, but when I came to run it the next year the rubber pipework had gone soggy and black goo got sucked into the heater. Now that did cause me grief, so on the basis I probably use about 15 litres of fuel a season in it I just run it on Dino now.
Offline william crosby
« Reply #12 on: November 25, 2012, 05:21:29 PM »
i am looking for a diesel one complete if any one has one for sale
thanks william
« Reply #13 on: November 25, 2012, 06:41:50 PM »
Ive got a B4 (no 'n') that looks a bit like this lurking somwhere -
...apart from mine is black for some reason.
I heard that that VW camper owners were keen on them for some reason (i mean the split or bay windows - not modern ones), so you might like to try pushing it to them?
I had another ages ago, that came with my landrover 101 (my 2nd unit came from someone else's 101) - i swapped it for the D2 when i swapped the V8 for a TDI, but, in hindsight, if i needed a separate tank for the D2, i may as well have stayed with the B4 : (
Ive heard that some get lock-out too, but my D2 certainly does not.  Theres different controllers for them also, so it may be to do with them also.
I spoke with a helpfull service agent once who went into, if i didnt want to use the controller, just wire a switch between x and y (etc) on the loom... but my controller was fine.
If you ever come across the website again that goes into the D2 / D4 bio issue, id be keen to read.  I will have a look for it myself now!
« Reply #14 on: November 25, 2012, 07:10:09 PM »
I had a look and cant find the site, it was deep in another site somewhere.
Heres an informative bit about lockout.
http://www.ybw.com/forums/showthread.php?t=72442
And right at the bottom of this page, is info about bio diesel. Its worth going to the home page and reading up on these guys.
http://letonkinoisvarnish.co.uk/Eberspacher_Fuel_1.html
« Last Edit: November 25, 2012, 07:15:47 PM by greasemonkey »
