Author Topic: Graphics style  (Read 7169 times)
Graphics style
« on: December 11, 2010, 01:45:08 AM »
Just spent a little while messing around with graphics, colours and text size, font and weight, to try and suggest a uniform style based on graphics on GL's site.
Efforts to date can be seen on this page ... http://www.biopowered.co.uk/wiki/GL_Processor
Anyone got any comments?
Re: Graphics style
« Reply #1 on: December 11, 2010, 10:05:13 AM »
looks good i perticularly like the way its drawn!
i need a drawing like this with all pipes and sizes and measurements so i can build a processor myself...
thx
Re: Graphics style
« Reply #2 on: December 11, 2010, 10:55:42 AM »
There should be enough on GL's site to get you started.  However, generally speaking, if you are using a TAM or a Leo, you want 22mm oil pipe work and 15mm vapour pipe work. If you can fit 28mm pipe work between the tank and the pump suction, so much the better.
As for dimensions, it's what fits the space you have available.  There are lots of photos of examples on GL's site.  Just a few basics that are some times overlooked:
1)  Make sure all the pipe work and processor are sufficiently high off the ground to get your glycerol collection container under the drain.  I'd use that as your starting point and layout the pipe work and tank from there.
2) Make the condenser as long as possible, but try and have the top of it not much higher than the top of the processor.
3)  Keep all the pipe work as short as possible, using as few bends as possible and try to use formed bends, especially on the pump suction.
4)  Don't spend too much time making it look fancy and neat, because a pound to a pinch of poo, you'll be modifying it within a few months!
HTH
Re: Graphics style
« Reply #3 on: December 11, 2010, 12:28:40 PM »
That is excellent Julian, great work dude.
do we need diesel? if not then we could use yellow for bio and orange for wvo and maybe have water as darker blue to set it apart from methoxide?
« Last Edit: December 11, 2010, 12:31:38 PM by Chug »
Re: Graphics style
« Reply #4 on: December 11, 2010, 11:05:42 PM »
Any comments on this
before I push on.  It took quite a while, so don't want to waste time going further if others aren't happy.
Re: Graphics style
« Reply #5 on: December 11, 2010, 11:11:47 PM »
friggin awesome!!!
the oil in? where from?
love this diagram.
what app drew that?
Re: Graphics style
« Reply #6 on: December 11, 2010, 11:16:24 PM »
disstillate part where does it come from? can only see a vent pipe?
Re: Graphics style
« Reply #7 on: December 11, 2010, 11:25:41 PM »
We working on two threads at a time now ... I'm getting confused!
Sorry, missed this bit ... Oil in from settling tank.
Re: Graphics style
« Reply #8 on: December 13, 2010, 11:11:33 AM »
Just seen this, that's bloody brilliant Julian!
Re: Graphics style
« Reply #9 on: December 13, 2010, 01:00:22 PM »
Sorry Chug I missed this post!
I included dino diesel for use on veg oil circuits where I think it will be needed.  In retrospect I'll make Methanol and Methoxide the same colour and I will darken the water a little (wanted to stick to pastel shades so nothing is too "in your face", far easer on the eye), but on the finished schematic, now posted, the difference is fairly obvious.
So, if everyone is happy ... Keith, do you want me to have a bash at the schematic for your processor?
Re: Graphics style
« Reply #10 on: December 13, 2010, 01:56:14 PM »
Julian, what software did you use for those graphics?  Is it worth uploading a template/sources here somewhere?
Re: Graphics style
« Reply #11 on: December 13, 2010, 03:26:07 PM »
Software was corelDRAW, a vector package.  Very accurate for graphics, you then have to export as a bitmap file.  Takes a lot of getting used to if you've not used vector software before.  Probably available from various down load sites depending on you views on copyright!  I only have an old version (v10) but perfectly good for this work.
I've already put a master up as a guide http://www.biopowered.co.uk/wiki/File:Wiki_graphics_master.png, which I will update as I get new components etc  It's a bitmap but people may still be able to copy and paste if they use bitmap packages.  If it's of any use I'll happily upload the corelDRAW file too, but if no one uses it, it will be PITA updating two files instead of just one.
Re: Graphics style
« Reply #12 on: December 13, 2010, 04:09:19 PM »
Wonder if there's any decent freeware vector graphics packages that can import CoralDraw vector files?
http://inkscape.org/  might be worth a try.
Edit: Just noticed that it's a fork of Sodipodi, which I've used before (was very good!)
« Last Edit: December 13, 2010, 04:23:11 PM by tony »
Re: Graphics style
« Reply #13 on: December 13, 2010, 04:30:56 PM »
Sounds similar, might be worth a try especially if it will import .cdr files.  Just realised the wiki will only let you upload bitmap files, but I could put it in my web space for down load if I can work out how!
Any how I can email you the file if you want a ply when you download Inkscape.
Re: Graphics style
« Reply #14 on: December 13, 2010, 04:34:39 PM »
Hang on, I'll add cdr to the wiki permitted extensions for upload.
Edit: OK, done.
« Last Edit: December 13, 2010, 04:39:48 PM by tony »
