Author Topic: Mono pump in action  (Read 13787 times)
Mono pump in action
« on: October 14, 2012, 07:04:43 PM »
Check this out - my poor old mono labouring through some WVO, using the footer valve/filter that KH gave to me many years ago :)
http://www.youtube.com/watch?v=dTpOjcb1IsQ
Re: Mono pump in action
« Reply #1 on: October 14, 2012, 08:04:08 PM »
Empties it quicker than Julian does a glass of red  :P
« Reply #2 on: October 14, 2012, 08:06:47 PM »
And a lot quieter.
Always a worry photographing into a barrel that you'll drop the camera.
« Reply #3 on: October 14, 2012, 08:08:50 PM »
That was my Android phone, should've turned it to the other orientation (landscape) in hindsight, ah well.  Yes was a little worried!
« Reply #4 on: October 14, 2012, 08:28:34 PM »
I cant see what you have on the end of the pipe?
I cant recall what its called (and now cant find a photo) but on mine, ive got this little bsp 'cage' thing (mesh filter) but the trouble is the surface area of it is too low, and the holes too small, so it gets blocked way too easily.
I want something on the end of the suction pipe, so as to avoid sucking up snails etc (i never used to have a problem with snails until we moved, and now... they dont half block pipes well!) but have not been able to find something suitable.
Ive considered a washable cartridge filter, but id most like something 'snail proof' on the end of the pipe.
« Reply #5 on: October 14, 2012, 08:34:37 PM »
Yes it's one of these:
http://www.ebay.co.uk/itm/1-BSP-CHECK-FOOT-VALVE-STRAINER-NON-RETURN-FUEL-OIL-/400216205851
The one-way valve is useless as it jams open on the gunk, not that the mono cares as it self primes anyway.  And it does block frustratingly regularly,
I'm experimenting with a Y valve on the pump discharge (Keith gave me one at the last BBB), so far it's OK but I've yet to graduate it to running without the filter on the footer valve as well - though I've picked up a 1" coarse stainer to try at the pickup end - one of these:
http://www.ebay.co.uk/itm/1-SUCTION-HOSE-STRAINER-WATER-PUMP-DRAINAGE-IRRIGATION-/120546380508
I think the Y valve could do with extending somehow to capture more without blocking but we'll see.  That or graduate to a full 10" filter housing.
« Reply #6 on: October 14, 2012, 08:38:13 PM »
Wait until one slithers up the angled waste pipe on the outside of your house,great fun when the washing machine discharges into it!
Offline Rossey
« Reply #7 on: October 14, 2012, 09:07:56 PM »
Is that veg?
It looks really dark.
« Reply #8 on: October 14, 2012, 09:23:32 PM »
I keep looking out for a cheap mono pump - they seem to be ideal for moving thick veg around
« Reply #9 on: October 14, 2012, 09:36:09 PM »
No good looking on ebay ... Tony and me got that stitched up with automatic searches!
But if you can find one they really are the business.
« Reply #10 on: October 14, 2012, 09:39:36 PM »
Ive seen them on ebay reasonably frequently - maybe every couple of months?  If you wanted one for under £50 i think you would have to wait a while, but if you were happy to spend up to a ton, i think you would get one fairly quickly?
I think mine was £40, but it needed a new rotor and stator - i think it worked out about £100 all in.
« Reply #11 on: October 24, 2012, 11:23:03 AM »
Is that veg?
WVO always looks dark in 60l drums plus the black layer of BCBs on the bottom doesn't help :)
« Reply #12 on: October 24, 2012, 01:15:16 PM »
Just spotted these on ebay -
http://www.ebay.co.uk/itm/Pond-Foot-Valve-with-strainer-3-4-hose-connection-Brass-/310477264827?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item4849e317bb
The tail in the photo is 3/4 bsp, but that could obviously be swapped.  The cage looks like it would block less frequently than the mesh ones, but still stop snails etc from getting up the pipework.
Not too bad a price either.
« Reply #13 on: October 24, 2012, 01:28:56 PM »
Oooh nice find :)
I like that.
At the moment I'm using 1" reinforced hose (the trouble with braided is that the pump sucks so hard it just goes flat!).  However it's just water hose and goes brittle and cracks after a few months.  Any ideas what I could use that a) won't get sucked flat b) will stay flexible with oil use?
Edit: Thinking about it, I have got one of these on a shelf somewhere:
« Last Edit: October 24, 2012, 01:31:07 PM by Tony »
« Reply #14 on: October 24, 2012, 02:55:15 PM »
http://www.screwfix.com/p/reinforced-suction-hose-with-filter-7m-x-1/78767
That is what i use on my mono pumps suction side.  Its not very flexible, and if you do manage to kink it, the wire inside keeps the kink, but, if your application doesnt need a load of flexibility, its just the ticket.
You can buy it off ebay etc too, but, when i looked, buying a 'kit' from screwfix was the cheapest way to get the hose itself  (the plastic parts in the 'kit' break quickly, so dont buy it for them)
