Author Topic: Mercedes W202 saddle tank sump solution?  (Read 1306 times)
Offline DWRDeep
« on: May 23, 2025, 09:49:02 PM »
Hello all, I haven't found where to introduce myself here & I hope this is the right place to ask this question.
I have used waste veg oil in my cars for many years, filtered at various times via socks or water filters down to 1 micron.
Currently I'm running a lovely 98 Merc C250 TD Sport, & have been advised never to let it go below ½ tank full. It runs beautifully.  I know from whispers that people known as Spock & Chissel(sp?) successfully connected the tank halves with a sump modification, but I haven't found details.
I'm thinking of drilling a hole near the base of the upright tube in each sender unit, inserting tubes to hold the drain valves open, and connecting with a T so that both run to the main fuel feed.
Comments please?
Cheers, Phil
Re: Mercedes W202 saddle tank sump solution?
« Reply #1 on: May 25, 2025, 07:18:31 PM »
Hi Phil and welcome, sorry to say its a bit quiet on here at the moment, hopefully someone who can advise you will see your post.
Offline DWRDeep
« Reply #2 on: May 25, 2025, 08:31:56 PM »
Thanks -sadly, many forums seem to be this way now, probably as people gravitate more & more to social media - I fear that a lot of information is to be lost in this way, I'm not sure ...
« Reply #3 on: May 27, 2025, 07:01:33 AM »
Unfortunately Spock and Chissel didn't migrate across from the VOD. The information you require is locked in that forums archive that cant be accessed now. Shame.
Offline DWRDeep
« Reply #4 on: June 23, 2025, 05:59:30 PM »
This has apparently troubled many people (not just veggers) if looking at the various fora is anything to go by, and now I've bought a second-hand sender the solution seems so simple that all my head-scratching is ... comical. Of course, I could be wrong and if so I'll let you know, though the post I write may be unpublishable for the cursing.
On both this & the left hand sender already on my car I'll remove the internal feed tube & cut the black plastic tube which leads to the external feed about 10 mm above the base plate, fit twin left-hand senders, & link them  with a T barb to the normal feed line.
