Author Topic: Venturi wanted  (Read 5105 times)
Offline db
Venturi wanted
« on: November 27, 2023, 07:22:06 AM »
Hi, Does anyone have a venturi to sell? I built on from plans on VOD by dickjotec, it was a '15 minute' easy assemble from copper fittings. It worked great but the diagram is no longer available unfortunately. I Don't want to cast one.
Regards, Dawson
Re: Venturi wanted
« Reply #1 on: November 27, 2023, 07:00:25 PM »
I dont have one for sale but if you change your mind about casting one give me a shout. I have machined cores for several pump sizes.
Re: Venturi wanted
« Reply #2 on: November 27, 2023, 08:57:11 PM »
Dick is registered on here and logged in a few days ago.  You could try sending him a PM.
Re: Venturi wanted
« Reply #3 on: November 29, 2023, 04:26:59 PM »
What flow rate is the pump for this venturi?
Offline db
Re: Venturi wanted
« Reply #4 on: November 29, 2023, 06:40:24 PM »
It's a lowara pump, plate states 30l to 70l / min. Dick no longer has the diagrams, we have spoken.
Nigel, if casting can you just use solder  as opposed to lead?
« Last Edit: November 29, 2023, 06:45:30 PM by db »
Re: Venturi wanted
« Reply #5 on: November 29, 2023, 09:17:06 PM »
It was solder I always used.
Offline RichardP
Re: Venturi wanted
« Reply #6 on: November 30, 2023, 05:55:20 PM »
I've used Nigels venturi cores and they work well. I used a codgered stainless ladle to melt the lead/solder in and poured it into the assembled pipework, quite straight forward to do.
Offline db
Re: Venturi wanted
« Reply #7 on: December 01, 2023, 10:18:48 PM »
Ok Nigel, I'll have a go at that if that is OK. Is there still a transport link up to Leeds?
Re: Venturi wanted
« Reply #8 on: December 02, 2023, 06:37:49 AM »
How soon do you need a core? I'm going to Caroles sister in Rotherham next Saturday if that helps. I could leave it there.
Offline db
Re: Venturi wanted
« Reply #9 on: December 02, 2023, 12:11:18 PM »
That would be perfect Nige. Thankyou. Just let me know whendropped off and address please.
Daws
Re: Venturi wanted
« Reply #10 on: December 02, 2023, 09:22:16 PM »
Will do Dawson. I'll send a PM in the week to let you know all the details. It'll be the same place as last time we met up.
Offline db
Re: Venturi wanted
« Reply #11 on: December 03, 2023, 08:38:32 AM »
Thanks Nige. I will collect same day if that's OK.
Re: Venturi wanted
« Reply #12 on: December 04, 2023, 09:26:13 PM »
I've put into bag, two cores. One for a 40-60 lpm and one for a 80 lpm. Also in there is a precast 80 lpm venturi that you are quite welcome to have. It's not perfect but I'd be quite happy using it. I reckon though you may need to cast using the 8mm throat version to get the best out of your pump.
Offline db
Re: Venturi wanted
« Reply #13 on: December 06, 2023, 10:00:11 AM »
That's great Nige, thankyou. If I arrive Sat morning say 10am will there be someone in?
Re: Venturi wanted
« Reply #14 on: December 06, 2023, 04:21:54 PM »
The cores are still with me Dawson. We travel up on Saturday morning and we are an hour away from Caroles sister. I'll be in touch when we set off.
