Author Topic: Excess Methanol.  (Read 1967 times)
Offline DavidA
Excess Methanol.
« on: August 29, 2022, 04:48:53 PM »
Lat's assume that you have made a test batch using 200 mL methanol per Litre. It looks ok, but there is a thin 'skin' on the surface.
Is this excess methanol (maybe you should have used 180 mL per Litre) or what is it. And what is the definitive test for excess methanol.
Just wondering.
Dave.
Offline countrypaul
Re: Excess Methanol.
« Reply #1 on: August 29, 2022, 05:27:51 PM »
Methanol and bio are usually totally miscible. A picture would help can you post a photo of the "skin", especially of the meniscus (The upward or downward curve seen at the top of a liquid in a container).
« Reply #2 on: August 29, 2022, 06:44:29 PM »
I've had that before when taking a sample from the batch after stage1. I've always assumed it was a skin of soap
Offline DavidA
« Reply #3 on: August 29, 2022, 07:05:34 PM »
I'll do a 10/90 on that batch and report back after that. The skin doesn't seem to be getting any thicker although it has stood for about three week.
« Reply #4 on: August 30, 2022, 09:46:46 AM »
It won't be methanol.
Paul, you say bio and methanol are miscible in all proportions but when I've done expts on 10/90 ratio's I have found there is separation when the bio gets up to 30 to 40%. It's very hard to see if the bio colour is very light but its there.
Offline countrypaul
« Reply #5 on: September 01, 2022, 02:36:28 PM »
I did say usually - because there is always the possibility of something strange happening.
I did have one batch where I got three layers, glycerol at the bottom, bio/veg oil in the middle and a third layer above that I am still unsure what it was. I had processed in the usual way but after stage 1 dropped everything into barrels and had left it far a couple of weeks. It was a clear liquid that decomposed when heated rather than boiling away. It left a carbon residue when heated strongly as it decomposed. For various reasons, I left it in the barrels with some additional catalyst and when I checked it between 1 and 3 months later the third layer had gone and the bio was a pass. It might have been soap, but as I used sodium why was it still liquid. The layer had been quite thick and obvious (1-2"), and immiscible with oil which would suggest not soap. Never worked out what it was.
I have on several occasions added more bio to a 27/3 test going as far as 27/15 but never seen a separate methanol layer - but probabably never looked for it that closely either.
In the same way that water in methanol causes the Warnquist test to give a high precipitation, could something else in the bio (or soluble in methanol and not bio) cause a separate layer of "methanol" to form.
David described it as a skin, so I would tend towards Nigel's view of it being soap.
